br7sv9x8 Posted February 26, 2005 Share Posted February 26, 2005 hello, i just want to know that is the signal lights in the back suppose to light up when you drive or does it only signal and the bottom tail lights, light up?? it would be great if some one can take a pix of there car and explain it to me thanks alot guys. -br7sv9x8 Link to comment Share on other sites More sharing options...
fbi012 Posted February 26, 2005 Share Posted February 26, 2005 top part of the tail light is for turn signals only. Brake lights are bottom and third lights. Car lights are bottom only. Link to comment Share on other sites More sharing options...
br7sv9x8 Posted February 26, 2005 Author Share Posted February 26, 2005 so there is no way you can make it light up on top and also signal at the same time? -br7sv9x8 Link to comment Share on other sites More sharing options...
axis008 Posted February 26, 2005 Share Posted February 26, 2005 I'm sure you can by switching around the wiring. Would probably require cutting the wires and rerouting them and/or attaching extra wire to light up more than there should be. Unless there's an easier way that I can't think of? -ben Link to comment Share on other sites More sharing options...
TRS Posted February 26, 2005 Share Posted February 26, 2005 I think it could be done by changing sockets and bulbs for the top portions to dual fillaments, and tapping into the bottom tail lights. You could probable change all 4 to dual fillement so that they all operate as both tails and brake lights. There are some members on here that are very good at figuring out electrical mods. Just give 'em time to come up with a solution. Link to comment Share on other sites More sharing options...
br7sv9x8 Posted February 26, 2005 Author Share Posted February 26, 2005 thanks a lot guys for helping me out with the question if you guys know how to do it. Do you think you can post up some pix and show step by step that would be very great thanks alot again. -br7sv9x8 Link to comment Share on other sites More sharing options...
br7sv9x8 Posted February 27, 2005 Author Share Posted February 27, 2005 hello, ok i got it to work now it took me about 20 mins to find out how to make the top of the rear lights to work and stay on when i drive too it was easy. and it look really nice all i need to do now it tap it to the break lights so it will be on when i break thanks. -br7sv9x8 Link to comment Share on other sites More sharing options...
mwiener2 Posted February 27, 2005 Share Posted February 27, 2005 moved to exterior My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
