My first logging ever
Yebbey
so I've been ots stage 2 for about 40k miles. Here's some logs I took. I wasnt sure how I was supposed to do it, so I took 4. Any input from the gurus here woudl be much appreciated.
*** I put new logs where I tried to do 3rd to redline...but for some reason, I could not get to redline.***
romraiderlog_20090327_124515.csv
romraiderlog_20090327_124619.csv
romraiderlog_20090327_124815.csv
romraiderlog_20090327_124850.csv
I took a look at your first log, First Run ...
Take a look at time 1579 ms. Your timing is 6.5 degrees.
Take a look at time 1844 ms. Your timing is 6 degrees. The drop is due to the knock event detected.
The real question is... why are you running 6.5 degrees at 2.04 g/rev and 2726 rpm. This will cause a hesitation. It's really not good because with such low timing there will be uncombusted gas in the exhaust manifold. It might lead to burned valves or other bad things.
Revising map, its just a little during spool, please email to me next time.
Sometimes its difficult to tell if its shifting or engaging the tq converter, it retards timing for that too.
Contact us for all your tuning and performance parts needs! Etuning the legacy community since 2008!
Follow us on FACEBOOK | INSTAGRAM
[sIGPIC][/sIGPIC]
  • 3 weeks later...
