Catch22ska4 Posted March 12, 2009 Share Posted March 12, 2009 So I had previously posted a thread on the overheating issues of my 1997 LGT Wagon and had gotten good feedback leading me to believe that the head gaskets needed to be replaced. Well, I went ahead and did the complete engine kit w/ head gaskets and the the majority of the other gaskets/seals... However, now that it's done the car is still overheating, but there is not the white smoke and whatnot that seemed indicative of the blown head gasket. What could possibly be going on? Faulty temperature sending unit or sensor? The radiator isn't clogged at all and there is a new water pump, oil, oil filter, air filter, coolant, hoses, thermostat etc.... What is going on??? Thank you for all your help! Link to comment Share on other sites More sharing options...
RochNY91TSI Posted March 12, 2009 Share Posted March 12, 2009 Make sure that there's no air in the radiator or coolant lines by burping the system. Air in there can cause overheating Link to comment Share on other sites More sharing options...
Epicautoteks Posted March 17, 2009 Share Posted March 17, 2009 So I had previously posted a thread on the overheating issues of my 1997 LGT Wagon and had gotten good feedback leading me to believe that the head gaskets needed to be replaced. Well, I went ahead and did the complete engine kit w/ head gaskets and the the majority of the other gaskets/seals... However, now that it's done the car is still overheating, but there is not the white smoke and whatnot that seemed indicative of the blown head gasket. What could possibly be going on? Faulty temperature sending unit or sensor? The radiator isn't clogged at all and there is a new water pump, oil, oil filter, air filter, coolant, hoses, thermostat etc.... What is going on??? Thank you for all your help! Start up the car and turn your heater ON. Many times the system will get air in the system. Try it and good luck... Link to comment Share on other sites More sharing options...
Catch22ska4 Posted March 18, 2009 Author Share Posted March 18, 2009 Thanks for the help, I fixed the overheating problem finally, however my transmission might have gone now. This car is turning into so much more work/money than I had ever expected especially when I still owe money on it... Link to comment Share on other sites More sharing options...
Epicautoteks Posted March 18, 2009 Share Posted March 18, 2009 Thanks for the help, I fixed the overheating problem finally, however my transmission might have gone now. This car is turning into so much more work/money than I had ever expected especially when I still owe money on it... Ouch... I understand, but is worth it if you plan to keep your car. Once fix you will love n enjoy it. I suggest to have it inspected througly, but most likely sounds like a defective transmission. Epicautoteks Link to comment Share on other sites More sharing options...
987687 Posted March 19, 2009 Share Posted March 19, 2009 Even if your transmission is toasted the old 4 speed autos are pretty cheap used from a junk yard/wherever. or take the opportunity to do a 5MT swap Link to comment Share on other sites More sharing options...
Catch22ska4 Posted March 19, 2009 Author Share Posted March 19, 2009 I would love to do a 5MT swap but wouldn't even know where to start.. I'm sure I could find a tutorial on NASIOC or something?? Link to comment Share on other sites More sharing options...
