morrias Posted March 12, 2009 Share Posted March 12, 2009 This is my first foray into tuning. I just flashed the car to stage 1. It's a 5eat LGT. I'm just wondering if everything is in order here, or if there is anything I need to change? On the knock count sum, is it normal to see it increment a little like it did in the logs? This log is a 3rd gear pull from 2K to redline.3rdgearlogs.csv Link to comment Share on other sites More sharing options...
BLKGT5 Posted March 12, 2009 Share Posted March 12, 2009 -1.5 degrees of timing was pulled at 4.1k RPM's then it leveled out properly. How long have you been running stg1? It should adjust for that minor setting in the timing maps as it collects to the real time mapping. Link to comment Share on other sites More sharing options...
morrias Posted March 12, 2009 Author Share Posted March 12, 2009 That was the first major pull. At that point I'd been running it for about 10 minutes at that point. Link to comment Share on other sites More sharing options...
rtbrjason Posted March 12, 2009 Share Posted March 12, 2009 I would address the knock from 4015 to 4097rpm. Link to comment Share on other sites More sharing options...
mickeyd2005 Posted March 12, 2009 Share Posted March 12, 2009 Take a look at the base timing table. Pick a cell closest to 4000 rpm and 2.8 g/rev. Drop it by 0.7 degrees. Then take a look at the cells around it. Drop the adjacent cells by 0.35 degrees to smooth it out as necessary. Link to comment Share on other sites More sharing options...
Spec B Posted March 12, 2009 Share Posted March 12, 2009 Overall I think it looks really good. I would pull .5 degrees of timing in the area you had the knock event. WOT pulls should be consistantly knock free IMO. You do not need to log A/f (it is pretty useless once you are in boost) or atmospheric pressure (just make a note of it before the log) Link to comment Share on other sites More sharing options...
morrias Posted March 12, 2009 Author Share Posted March 12, 2009 Thank you very much. I'll make the changes and try it out again today. I need to find a good drag strip as these 3rd gear redline's get you some pretty high MPH. Link to comment Share on other sites More sharing options...
morrias Posted March 12, 2009 Author Share Posted March 12, 2009 Here's a screenshot of before making any changes. So on the 4000 rpm row at about the 2.7 column, I'd back it off by .7? Then to left and right of that number back it by .35? I highlighted in red what I think I should change. Just wanted to verify. Thanks!! Link to comment Share on other sites More sharing options...
mickeyd2005 Posted March 12, 2009 Share Posted March 12, 2009 The three cells you picked are correct. You can only drop timing in 0.35 degree increments. That's how the ecu works. I'll update the map when I get a chance. Link to comment Share on other sites More sharing options...
