Matt Murray Posted March 6, 2009 Share Posted March 6, 2009 I have a 1999 legacy gt wagon, I noticed that I stopped at a stop sign and when I started to go the engine reved up but did not move. I put it in park then drive and after a second the car began to move. It did this several trimes. I checked the fluid level and all is fine. the car has only 60239 miles on it and I will be doing the fluid chaange this weekend, any idea if that will fix the probllem? Thanks, Matt iresqu101@hotmail.com Link to comment Share on other sites More sharing options...
Bdubs Posted March 7, 2009 Share Posted March 7, 2009 What is the color of the ATF? If it is a very dark brown redish tint, it's in need of a change. Add a product called Lubegard along with the new ATF, and it works very well to cure the slippage. Link to comment Share on other sites More sharing options...
Dawrah Posted March 7, 2009 Share Posted March 7, 2009 or throw a bottle of lucas transmission fix, always good results with lucas products Link to comment Share on other sites More sharing options...
Matt Murray Posted March 8, 2009 Author Share Posted March 8, 2009 the fluid looks fresh (red). I am going to change the filter and put in the lucas in the mornong. hope that helps. Link to comment Share on other sites More sharing options...
Matt Murray Posted March 8, 2009 Author Share Posted March 8, 2009 My `1999 wagon gt with 2.5 62300 miles. has a slight miss/vibration it gets really bad at about 3000 rpms but today I put in new plugs and wires and it helped alot but it is still there but not as bad. any idea what else could cause the miss/vibration? Please help. Matt Link to comment Share on other sites More sharing options...
Bdubs Posted March 8, 2009 Share Posted March 8, 2009 It may be a simple intake problem. Check your throttle body, all the air intake parts and be sure they are nice and clean, and everything is tight. Be sure all the Vac. hoses are fastened snug. Link to comment Share on other sites More sharing options...
Matt Murray Posted March 8, 2009 Author Share Posted March 8, 2009 would it miss like that if the coil pack is bad? Link to comment Share on other sites More sharing options...
