cptplt Posted February 28, 2009 Share Posted February 28, 2009 I'm being cheap and want to put a set of Nokian CS tires 215/65-16 on my 08 OB.(I already run 215/65-16 X ices on the OB for winter) The Nokians are presently on my Winne Rialta rv. They are truck load rated (109, D load). what I want to know is what pressure should I have on these tires when they are on the OB. on the Rialta they are supposed to be at 60psi (tires max 74psi). is there a minimum pressure I need to run them at before worrying about them not being seated on the rims and falling off? does high 40s sound like a good idea to run them on the OB? Link to comment Share on other sites More sharing options...
Coupon Posted March 3, 2009 Share Posted March 3, 2009 Do you have a link to these tires? Min. pressure for a load range D tire is 40 psi. Since the tires are designed to be carrying a lot of weight, you shouldn't need to fill them over 40. But your car is the wrong application for these tires. Link to comment Share on other sites More sharing options...
cptplt Posted March 8, 2009 Author Share Posted March 8, 2009 thanks for the info, I run my tires on the OB at high 30s already so if I'm 40 or a little over I doubt I will notice too much http://www.nokiantires.com/tyre?id=11889&group=3.01&name=Nokian+Hakkapeliitta+CS I have had a lot of trouble getting replacement tires for my Rialta when on the road (one year Nokian had to fedex me the only one left in N America when I was stuck 1000 miles from home when I lost 2 tires) , there are really only two tires of the correct size and load rating "easily" available in N America for the Rialta - and since there is a lot of tread left on these Nokians I want to put a non directional tire on the rialta for the future so rotations and even using the spare is easier and shift them to my OB as the size is ok. Link to comment Share on other sites More sharing options...
