chrisinky Posted February 23, 2009 Share Posted February 23, 2009 I had a few units made for my car and was wondering if there would be any interest if I parted up the last few boards for sale... There are two separate boards: Board 1: Key bypass + clutch bypass + trunk integration (you still need ADS-SUB-RNG module) Board 2: Sunroof controller (- pulse for open, - pulse for close) Any interest in these at all or should I scrap the excess PCB? Cost would be minimal, and if there was a decent amount of interest I could even source enclosures. I'd say $35 + shipping roughly for either... Link to comment Share on other sites More sharing options...
PeterJMC Posted February 23, 2009 Share Posted February 23, 2009 what does the sunroof module actually do? Link to comment Share on other sites More sharing options...
chrisinky Posted February 23, 2009 Author Share Posted February 23, 2009 It interfaces between your sunroof switch and brain wiring. It uses the factory brain (to keep you from frying the motor). A single - pulse to "open" would fully open the sunroofA single - pulse to "close" would close it 1/2 way, a 2nd pulse would close it all the way My remote start had only 3 outputs.... So as-is (I can easily disable/enable the feature) you can fake a 4th output... I set my 3rd output as latched for 30 seconds.....So... Hit aux 1 windows downHit aux 2 sunroof openhit aux 3, then within 30 secs hit aux 1 windows closehit aux 3, then within 30 secs hit aux2 sunroof closes 1/2 way, hit it again closes fully If your alarm has enough outputs, or you aren't controlling windows/other stuff that uses all your other outputs up then your good to go. You will need an aftermarket alarm or remote start to interface though. Chris Link to comment Share on other sites More sharing options...
lossol Posted February 23, 2009 Share Posted February 23, 2009 What does the ADS-SUB-RNG plug into? your board? VBG1 gauges available at www.gtboostgauge.com Link to comment Share on other sites More sharing options...
chrisinky Posted February 23, 2009 Author Share Posted February 23, 2009 Yes it will plug into my board. My board would only enable the key chip bypass when the remote start is running/active, it will also only bypass the clutch switch when the remote start is attempting to start the car. Any other time - the factory chip in the key feature will work, and the clutch switch would be required when manually starting the car. Also note - for those wanting to use fancy or even cheap-ass chip-less keys, you could very easily use the ADS-SUB-RNG to bypass the factory keychip security. Chris Link to comment Share on other sites More sharing options...
