Yebbey Posted February 20, 2009 Share Posted February 20, 2009 When I drive home and park, there's always ticking and dripping sounds that last for maybe 10-15 minutes. Should I be worried about either of these sounds. I can't really tell where the dripping sound is coming from and I dont see anything on the floor. Link to comment Share on other sites More sharing options...
Mr. Sinister Posted February 20, 2009 Share Posted February 20, 2009 Ticking is probably the heat shields from expansion/contraction. The dripping noise may be the same. Link to comment Share on other sites More sharing options...
Yebbey Posted February 20, 2009 Author Share Posted February 20, 2009 yeah, the ticking I wasn't too worried about, but the dripping is what I"m wondering more about Link to comment Share on other sites More sharing options...
987687 Posted February 20, 2009 Share Posted February 20, 2009 If you aren't losing fluid from anywhere it is probably just part of the car cooling down. Link to comment Share on other sites More sharing options...
FrozenNorthLGT Posted February 20, 2009 Share Posted February 20, 2009 Check all your fluid levels....check the topside of the undershield for any fluids....look at the engine from underneath for any signs of fluids running down...nothing found, then don't sweat it. . Link to comment Share on other sites More sharing options...
PeterJMC Posted February 20, 2009 Share Posted February 20, 2009 If you had your A/C on it's probably just the condensation dripping off the system. Look under your car and you should see the puddle. Link to comment Share on other sites More sharing options...
