03LegacyWgn Posted February 7, 2009 Share Posted February 7, 2009 Hey guys! just a quick question, when i start my car, my ABS light comes on and blinks one long blink then one short blink, it does this a few times then goes out or goes out when i shift the car into gear. It did this last week when i had my car in my shop to change the oil, didn't do it all week now is doing it again, im sure the ABS still works when the car is in motion (will test tomorrow when i go to work) Now it was warm today, between -5 to 0 deg C and it was around the same temp last sat, but bitterly cold during the week. Any ideas? im living in a small town for work that doesn't have a Subie dealer, if needed i could drive a few hrs to my uncles shop and run the ABS reader to see if it has any codes. thanks for the input guys! 03 BH Mods: Group A Alt & Crank Pullys and end links, CIA, JDM L7 Grille, JDM HID lights, JDM rear tails Stromung CBE, KYB GR2's W/ H&R springs. Link to comment Share on other sites More sharing options...
03LegacyWgn Posted February 8, 2009 Author Share Posted February 8, 2009 Well it blinked this morning, tested the ABS and it still works, didnt blink after work since it was -5 any ideas? 03 BH Mods: Group A Alt & Crank Pullys and end links, CIA, JDM L7 Grille, JDM HID lights, JDM rear tails Stromung CBE, KYB GR2's W/ H&R springs. Link to comment Share on other sites More sharing options...
Levish Posted February 10, 2009 Share Posted February 10, 2009 did you check brake fluid level?, make sure its up to the very top mark not in between or at the low mark Link to comment Share on other sites More sharing options...
03LegacyWgn Posted February 11, 2009 Author Share Posted February 11, 2009 that i did not, i will check that today, thanks! 03 BH Mods: Group A Alt & Crank Pullys and end links, CIA, JDM L7 Grille, JDM HID lights, JDM rear tails Stromung CBE, KYB GR2's W/ H&R springs. Link to comment Share on other sites More sharing options...
