JS07LGT Posted August 8, 2009 Share Posted August 8, 2009 This same thing has just happened to me. on the way home i noticed the gas light was on even after i had just filled up this morning. I have disconnected the battery cables and tightened the gas cap but still the lights blink. I work at a Subaru dealership so i'll have to see what it is in the morning. I just put on a SPT intake 1000 miles ago could this cause all my warning lights to go nuts? Link to comment Share on other sites More sharing options...
duvalgotasubie Posted August 16, 2009 Share Posted August 16, 2009 so i just bought my new baby a subie sti 2005 and i have had it for 3 days and i got the cel and cruise light but i dont even have cruise control? help? have a turbo back exhaust and a cold air intake, otherwise stock. Link to comment Share on other sites More sharing options...
ehsnils Posted August 16, 2009 Share Posted August 16, 2009 Read the codes, Autozone or similar outfit may be able to help you. Do this as soon as possible and when you have the code you will know what the problem is. Depending on the code you may or may not risk toasting the cat. (unless the code is that you have a dead cat) Since it's likely to have an electronic throttle the cruise control is essentially only the existence of the steering wheel handle and possibly ECU software. Just ignore the cruise control flash, that's just a secondary effect of the CEL. Link to comment Share on other sites More sharing options...
