wpmarky Posted January 30, 2009 Share Posted January 30, 2009 Newbie here that needs help, will these fit on an 08 LGT? "18x8, 35et. dual 5 bolt pattern 5x100/112" What size tires should I get for them? Link to comment Share on other sites More sharing options...
lawl Posted January 30, 2009 Share Posted January 30, 2009 are you lowered? slammed? 18x8.... i've had good luck with 225/40/18s in teh past. any bigger and I would start rubbing im lowered on coils. unfortunately without further information it's hard to help you out. the wheel FAQ is very helpful in this forum as well. (according to the FAQ this is not an ideal offset but some people have fit some pretty aggressive fitments here with some modifications) car for sale. PM me! Link to comment Share on other sites More sharing options...
wpmarky Posted January 30, 2009 Author Share Posted January 30, 2009 thanks lawl, I read the FAQ and noticed that the offset doesn't fall within the range. My car isn't lowered, it's a stock 08 Spec.B if that matters. I probly won't lower it in the future either (coils are last on my list, just sways for now) What does that offset mean? does 35 matter that much? Link to comment Share on other sites More sharing options...
wpmarky Posted January 30, 2009 Author Share Posted January 30, 2009 i'm pretty much wondering if these will fit: http://sfbay.craigslist.org/sfc/pts/1012786928.html Link to comment Share on other sites More sharing options...
urfsin Posted January 30, 2009 Share Posted January 30, 2009 Yes they will fit, but they will also stick out a bit. It's an "aggressive" look if that's ok with you. Slide It Sideways Link to comment Share on other sites More sharing options...
lawl Posted February 1, 2009 Share Posted February 1, 2009 they will stick out and the problem is if you're lowered they will grind/rub/whatever against either the metal fender lip, your wheel well lining, etc. if you're stock height i dont see there being much of an issue. another thing is if you're upgrading wheels and brembos may be in your future you'll have to consider getting wheels that fit brembos, because you'll end up ditching this set at that point anyway. another issue is resale. if you get a fairly ubiquitous subaru wheel brand like enkei or rota you'll have an easier time reselling the wheels if you decide you dont want them anymore. hope this helps. car for sale. PM me! Link to comment Share on other sites More sharing options...
