MotoFanatic Posted February 19, 2005 Share Posted February 19, 2005 Hi! Well, I took my car to a high performance wheel shop today because I had a slight steering wheel shake at higher speeds. What does this mean? Well, as it turns out, this meant doing 2 things: 1) Take wheel off and use a balancing machine to spin balance the tire. Then put wheel back on. 2) Once all have been spin balanced OFF the car and tires put back on, they jack the front end up and use a machine to spin the front wheels at a high rate of speed to balance it even more. Naturally, the car is smooth now but the question comes, are there issues/damage that may result out of spinning only the front wheels in a AWD car?? Thanks for any opinions on this! -Moto Link to comment Share on other sites More sharing options...
Jedi Pimp Posted February 19, 2005 Share Posted February 19, 2005 auto or manual tranny? Link to comment Share on other sites More sharing options...
MotoFanatic Posted February 20, 2005 Author Share Posted February 20, 2005 Hey Jedi Pimp, It's a manual. Since you're from the DC area, you might know the place. It's Radial Tire Co. in Silver Spring. Great bunch of guys out there. -Moto Link to comment Share on other sites More sharing options...
Jedi Pimp Posted February 21, 2005 Share Posted February 21, 2005 I do know that place very well they did my Supra back in the day. I guess you might run the risk of overheating your center differential but if they just do it for a short while it's probably ok. Link to comment Share on other sites More sharing options...
