Vert1go1 Posted January 17, 2009 Share Posted January 17, 2009 I just bought an 07 spec.B recently. When I removed the stock wheels/tires to put on a set of 17" with snow tires, I noticed the inside shoulder of the front RE050As were fairly wore, almost bald. Definitely need replacement. That's not a big deal though. My concern is why they have worn so much on the front inside shoulders. Does the spec.B in general wear the inside shoulders hard? Or do I have an alignment/camber issue? I'd rather spend the $50 for an alignment than kill my new snow tires in a couple thousand miles. The stock tires have just over 19,000 miles on them, but the rears look great, at least half tread remaining. Second part of this. If I buy two new RE050A for the front, and keep the other two good ones on the rear, will this screw with the viscous center diff, or is it just the front and rear diff dealing with side to side variances that matters? Thanks Dave Link to comment Share on other sites More sharing options...
ultimakf7 Posted January 17, 2009 Share Posted January 17, 2009 Sounds like an alignment issue, but in general.. the RE050As simply don't last long. If you have heard rubbing when driving while having the steering wheel completely turned, that's a rubbing issue. Link to comment Share on other sites More sharing options...
ultimakf7 Posted January 17, 2009 Share Posted January 17, 2009 The general consensus on tires on AWD cars is if the tread is off by more than 1 or 2/32nds, then you should replace all 4 tires. Link to comment Share on other sites More sharing options...
fonts Posted January 18, 2009 Share Posted January 18, 2009 While I found that my RE050 wore fairly quickly there certainly was no issue at all with uneven tread wear. Have you been rotating your tires???? I agree that if you have that much uneven wear you may have an alignment issue. Also agree that you may have major issues with replacing only 2 tires. Link to comment Share on other sites More sharing options...
blackfang Posted January 18, 2009 Share Posted January 18, 2009 Search the forum regarding replacing tires before just replacing 2 of them. I am sure just 2 may be a bad thing. [SIZE=1][URL="http://public.fotki.com/blackfang/"]Pics[/URL] [B]08 KawasakiZZR 600- exhaust and other mods 98 Camaro Z/28 HT- some mods......street/strip car 07 Legacy 2.5i- SPT exhaust...daily driver[/B][/SIZE] Link to comment Share on other sites More sharing options...
