instantfury Posted January 9, 2009 Share Posted January 9, 2009 anybody gotta clue as to how this could happen? its the connector right above the left pulley. Link to comment Share on other sites More sharing options...
PeterJMC Posted January 9, 2009 Share Posted January 9, 2009 Connector housing cracked and the housing seperated? If so, probably the cold weather made the plastic become brittle and crack Looks a little too blury for me to clearly see. Link to comment Share on other sites More sharing options...
instantfury Posted January 9, 2009 Author Share Posted January 9, 2009 yea sorry bout the blur, all i had was a camera phone. the housing itself isnt cracked its more like it was worn down, ill try to get a better picture up. thats the reason im so confused as to how it would happpen. only way i could think is that the belt came off and wore it down, but the belt has never fallen off as far as i know Link to comment Share on other sites More sharing options...
wngan9447 Posted January 13, 2009 Share Posted January 13, 2009 Heat and vibration maybe... it's weird that a piece like that can wear down... Link to comment Share on other sites More sharing options...
SBT Posted January 13, 2009 Share Posted January 13, 2009 Better clear pictures with some "stand-back" perspective on the location would be helpful, followed by clear close-ups. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
PeterJMC Posted January 13, 2009 Share Posted January 13, 2009 Have you tried to move the connector to see if you can pull it close enough tot he pulley to touch it? Link to comment Share on other sites More sharing options...
instantfury Posted January 13, 2009 Author Share Posted January 13, 2009 still from the phone. ill get the real camera out tonight. i can wiggle it but not nearly enough to get it to touch the pulley without the fear of breaking the connector. Link to comment Share on other sites More sharing options...
SBT Posted January 13, 2009 Share Posted January 13, 2009 Now with perspective, that looks to be the connector for your A/C compressor. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
instantfury Posted January 14, 2009 Author Share Posted January 14, 2009 heres a couple more, it was 0 outside so it still might be a lil blurry Link to comment Share on other sites More sharing options...
PeterJMC Posted January 14, 2009 Share Posted January 14, 2009 Can the pulley slide back and forth? Definitely looks like something has been constantly rubbing against the plug. If you rotate the pulley is there anything hanging off it? Link to comment Share on other sites More sharing options...
