BRP800 Posted January 8, 2009 Share Posted January 8, 2009 My LH low beam burned out. I ordered a pair of H-7 PIAA Extreme Whites to make sure both lights match. Couldn't remember if I'd put low beam PIAA's in 3 years ago. Also just noticed that both lower valance fog lights are out. Are they wired into the LH low beam circuit? Could it be a relay or fuse? The owners manual says something about the hand brake must be off, engine running in gear, and low beams on, for fogs to light. Yikes. Disregard. My apologies if this has been discussed before. Haven't been using the Suby much and spent a lot of time in the hospital. Any suggestions eagerly welcomed. EDIT: Thanks for the resounding help. Must still be the same kids that were here for my last (4) Suburus. Fog lamps are both on same fuse #29 15amp. H/L just burned out after 3 years and 18,000mi. Brainless fix. Link to comment Share on other sites More sharing options...
yulook Posted January 11, 2009 Share Posted January 11, 2009 Hey BRP800 What do you think of the PIAA Extreme?? I'm thinking about getting a set. Where did you order them? Link to comment Share on other sites More sharing options...
