Mach V Dan Posted February 22, 2005 Author Share Posted February 22, 2005 ops my bad, what i meant to say is it's alittle low off the bottom and is great at 5000 .i really need to proof read my posts first. I'm a little confused about your posts. Were you looking at the second graph in the thread, which is of a stock car? --Dan Mach V FastWRX.com Link to comment Share on other sites More sharing options...
Mach V Dan Posted February 22, 2005 Author Share Posted February 22, 2005 Dan, do you have the AFR ratio chart that goes with that dyno chart run? I didn't output that, but it's around 11.0:1 most of the way out. It dives rich at first, as it transitions from the stock fueling as the boost comes on. --Dan Mach V FastWRX.com Link to comment Share on other sites More sharing options...
Xenonk Posted February 22, 2005 Share Posted February 22, 2005 Sounds good Dan! I can live with 12:1 and 13:1. Keefe Keefe Link to comment Share on other sites More sharing options...
dynoguy Posted February 22, 2005 Share Posted February 22, 2005 dan what i see in the 1st posted graph is the power seems the same untill 3000+ rpms between stock and the tune. my stage 1 AP tune about 15 better from 2000 than stock. mike Link to comment Share on other sites More sharing options...
Mach V Dan Posted February 22, 2005 Author Share Posted February 22, 2005 dan what i see in the 1st posted graph is the power seems the same untill 3000+ rpms between stock and the tune. my stage 1 AP tune about 15 better from 2000 than stock. mike I usually start dyno runs from a steady state 1500 rpm, but it's difficult to get exactly the same throttle tip-in from one run to the next, so I would discourage trying to draw conclusions on the low-end of the chart, before about 2500 rpm. (I try to roll onto the throttle gently, so as not to make the car buck on the dyno. But not being a robot, I can't reproduce the same roll-on with each run.) But I'm glad you are happy with your car, Mike. --Dan Mach V FastWRX.com Link to comment Share on other sites More sharing options...
Mach V Dan Posted February 22, 2005 Author Share Posted February 22, 2005 Sounds good Dan! I can live with 12:1 and 13:1. Erk! 13:1 air/fuel will almost certainly result in detonation at wide-open throttle and full boost. --Dan Mach V FastWRX.com Link to comment Share on other sites More sharing options...
dynoguy Posted February 22, 2005 Share Posted February 22, 2005 i seen the same thing when we dyno'd my car but being an auto it was easier to dump the throttle the only thing that happens it depending if i was hi or lower in speed when the boost came on seemed to make a difference in my lower rpm #'s Link to comment Share on other sites More sharing options...
