etcetera Posted December 8, 2008 Share Posted December 8, 2008 Got a 98 Legacy with 2.2L and 146Kmiles. It misses at 2-3 gears. I plan to do plugs and wires, maybe fuel filter. What else should I replace as part of routine tuneup. It's also throwing a code which I will check shortly. Link to comment Share on other sites More sharing options...
987687 Posted December 8, 2008 Share Posted December 8, 2008 I did plugs, wires (only because one broke as I was taking it off...), air filter, injector cleaner, and coolant. I also ended up doing water pump and timing belt (because the water pump failed) Link to comment Share on other sites More sharing options...
etcetera Posted December 8, 2008 Author Share Posted December 8, 2008 Thanks for feedback... Given it has no distributor and dist. cap, what do I replace instead of it? Link to comment Share on other sites More sharing options...
ehsnils Posted December 8, 2008 Share Posted December 8, 2008 If it doesn't exist it doesn't have to be replaced. Just clean all high-voltage parts (cables and coil pack) so they are free from dirt. Dirt has a tendency to get conductive when there is condensation accumulating, which may happen during cold/wet weather. And that can cause misfires, so keep the parts clean avoid WD40 since it contains lubricant, use something that dries completely like brakleen. Link to comment Share on other sites More sharing options...
etcetera Posted December 8, 2008 Author Share Posted December 8, 2008 Thanks for the tip. Link to comment Share on other sites More sharing options...
