LegacyMUN2k6 Posted November 28, 2008 Share Posted November 28, 2008 http://cgi.ebay.com/2x-H7-H11-HB4-9006-Fog-Light-18-SMD-Hi-Power-LED-Bulb_W0QQitemZ270309219539QQcmdZViewItemQQptZAU_Car_Parts_Accessories?hash=item270309219539&_trksid=p3286.c0.m14&_trkparms=72%3A1199%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318 Link to comment Share on other sites More sharing options...
DMTaylor Posted November 29, 2008 Share Posted November 29, 2008 interesting option to colormatching HID low beams. Stock fog lights kinda suck anyway, and this would make for a good daytime running light option. Note: These bulbs will only work for 08+ as they are 9006 size, not H3 Link to comment Share on other sites More sharing options...
katalyst Posted November 29, 2008 Share Posted November 29, 2008 seems like it might cause glare for oncoming traffic though? Link to comment Share on other sites More sharing options...
TSiWRX Posted December 1, 2008 Share Posted December 1, 2008 ^ Shouldn't be a problem, given the factory fog's optics. But then again, I honestly don't know how powerful these things are....they may be insufficient for DRL use and/or true-fog use. They've had these on V-LED for a while now (look under their DRL replacement options). I haven't tried them, but I have tried their "SMT" 9XX solution, in red, when I was experimenting with my rear-fog setup, and it was woefully underpowered for daylight operation. Given that these are "bigger" units, and would make use of a deeper reflector dish in the fogs, I simply don't know. If someone's got the dollars to spare, it might be an interesting project, for sure. <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
NSFW Posted December 2, 2008 Share Posted December 2, 2008 If those are 1-watt LEDs, I'm guessing they're worthless. If they're 3-watt, then they're probably not bad. I'm not optimistic, though. Link to comment Share on other sites More sharing options...
PhilT Posted December 2, 2008 Share Posted December 2, 2008 If you are going LED fogs, <<<---------this is the way to go Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
TSiWRX Posted December 2, 2008 Share Posted December 2, 2008 ^ I agree..... I think that, currently, the multiple "bulb" LEDs are the only way to go. If those are 1-watt LEDs, I'm guessing they're worthless. If they're 3-watt, then they're probably not bad. I'm not optimistic, though. I've been out of the flashlight hobby for so long that I don't know, anymore, what these "surface mount" arrays consist of. Individually, they're definitely not that bright. In terms of what I think of traditionally, as "1W" and "3W" LEDs (and here, remember, please, when I got out of that hobby, the SureFire L6 was king of the production-line items so that was quite a while ago), in the rear-fog thread ( http://www.legacygt.com/forums/showthread.php?t=31502&highlight=rear+fog ), I'd commented, in post #7, on my then-desire to pursue the red1156-RLX5 "5W" (their terminology - it's actually a 3W side-firing, surrounded by an array of 4 surface mounts), but if you looked at their website, it has the following disclaimer: To prevent over heating, they will automatically dim if turned on for long periods of time. That made me rather afraid - that for a safety device (i.e. rear fog), that this LED, when overheated, would shut itself off in order to cool down. This would lead me to believe that this particular item would be more suited to only momentary actuation of the "bright/high" element. From what little LED-know-how that I retained from my flashlight days, I think that a more efficient heat-sink, custom, solution would be necessary in order to render a more capable LED-based fog than what brother PhilT and others have already accomplished. <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
