carrata Posted November 26, 2008 Share Posted November 26, 2008 So I've searched fairly thoroughly, looked at the flange from the outside, tried to guesstimate but... I can't seem to find the inlet size on the SPT V2 cat-back. (2.5" or 3"?) The midpipe is 3" and tapers down to 2.75" after the y-pipe. But is the inlet flange 3"? Ultimately, I'm looking for a quality catted downpipe that will mate properly with my current cat-back. Link to comment Share on other sites More sharing options...
Spec B Posted November 26, 2008 Share Posted November 26, 2008 From what I remember reading on the forum, I believe that the SPT is designed to work with the (smaller diameter) stock DP. If you run an aftermarket DP you will need to make sure it reduces from 3" to 2.5" so that it will mate with your exhaust. Link to comment Share on other sites More sharing options...
Spec B Posted November 26, 2008 Share Posted November 26, 2008 Ahh..this is where I read it. http://www.legacygt.com/forums/showthread.php?t=94237&highlight=SPT Link to comment Share on other sites More sharing options...
carrata Posted November 26, 2008 Author Share Posted November 26, 2008 Thanks for the link...I believe I read that thread at some point. What I don't understand is why the midpipe would be 3" all the way back to the Y if the flange at the inlet is only a 2.5". Does te pipe taper up to 3"? So if I went with the Cobb it would be: 3" dp -> 2.5" dp flange -> 2.5" mid-flange -> 3" midpipe....? Link to comment Share on other sites More sharing options...
05gtlimited300 Posted November 26, 2008 Share Posted November 26, 2008 ^correct Link to comment Share on other sites More sharing options...
carrata Posted November 26, 2008 Author Share Posted November 26, 2008 ^ Boourns. Link to comment Share on other sites More sharing options...
