myth Posted November 26, 2008 Share Posted November 26, 2008 Vehicle is a Legacy L Sedan 2002 Auto Subaru Legacy 2000~2002 wiring diagram http://64.85.6.121/diagrams/diagram.asp?ModelID=15451&MakeID=39&link=BULLDOG It shows: POWER LOCK WHITE (TYPE B) IN DRIVERS KICK PANEL, HARNESS FROM DOOR POWER UNLOCK GREEN/RED (TYPE B) IN DRIVERS KICK PANEL, HARNESS FROM DOOR TRUNK RELEASE LIGHT GREEN/YELLOW (5-WIRE) @ HATCH RELEASE SWITCH A few other source on the web shows the same wiring info. So I assume the above is correct. But I cannot find the above wires. For lock/unlock, I can see the harness from door but I cannot find them. For trunk, it seems that I need to disassemble the trunk release switch but I cannot disassemble it. Link to comment Share on other sites More sharing options...
myth Posted December 5, 2008 Author Share Posted December 5, 2008 Vehicle is a Legacy L Sedan 2002 Auto Subaru Legacy 2000~2002 wiring diagram http://64.85.6.121/diagrams/diagram.asp?ModelID=15451&MakeID=39&link=BULLDOG It shows: POWER LOCK WHITE (TYPE B) IN DRIVERS KICK PANEL, HARNESS FROM DOOR POWER UNLOCK GREEN/RED (TYPE B) IN DRIVERS KICK PANEL, HARNESS FROM DOOR TRUNK RELEASE LIGHT GREEN/YELLOW (5-WIRE) @ HATCH RELEASE SWITCH A few other source on the web shows the same wiring info. So I assume the above is correct. But I cannot find the above wires. For lock/unlock, I can see the harness from door but I cannot find them. For trunk, it seems that I need to disassemble the trunk release switch but I cannot disassemble it. I am installing a remote-starter; UltraStart G11t. I connected the other wires. Power unlock info is not sufficient; there are 2 wires w/ the same color on the same harness. The wire on the same row as lock is not the unlock. Instead, the wire on the row 3 is the correct unlock. The problem is that the remote-starter unlocks all the doors at 1st push. OEM remote unlocks only driver door at 1st push and all doors at 2nd push. I am still finding trunk release wire. I seems that I need to disassemble trunk release switch, but I cannot find a way. Link to comment Share on other sites More sharing options...
kb2spn Posted December 9, 2008 Share Posted December 9, 2008 You have all the information that you need,the after market keyless entry will unlock all doors.I don't think you will want to go thru the trouble of unlocking the driver door only.The tunk release is a five wire hook-up. Link to comment Share on other sites More sharing options...
myth Posted December 9, 2008 Author Share Posted December 9, 2008 You have all the information that you need,the after market keyless entry will unlock all doors.I don't think you will want to go thru the trouble of unlocking the driver door only.The tunk release is a five wire hook-up. I cannot even find 1 of 5 wire hook-up, unfortunately Link to comment Share on other sites More sharing options...
kb2spn Posted December 10, 2008 Share Posted December 10, 2008 One wire but you need a relay to break that wire and send a negative at the same time(five wire) Link to comment Share on other sites More sharing options...
