myth Posted November 26, 2008 Share Posted November 26, 2008 I am installing a remote-starter. Starter model is Ultra Start G11t and installed on the Legacy L Sedan Auto 2002. It cannot work without tach-signal, unfortunately. So I connected the tach-wire to the ignition coil in the engine-room through the window. Then the remote-starter works perfect. Now I need to pass-through a wire from driver side under-dash to engine room. I checked the under-dash but cannot find any hole to do it. How can I do it? Link to comment Share on other sites More sharing options...
AWDxBOOST Posted November 26, 2008 Share Posted November 26, 2008 drill a small hole or, there is a rubber grommit that 3 or so hard lines go thru (i think they are fuel lines) Link to comment Share on other sites More sharing options...
Detslider Posted November 26, 2008 Share Posted November 26, 2008 Removing the TMIC will give you access to a giant grommet. See pictures here http://www.legacygt.com/forums/showpost.php?p=2101962&postcount=130 eta: nevermind I see it's a 2002 your working on. Probably not the same. Link to comment Share on other sites More sharing options...
DMTaylor Posted November 26, 2008 Share Posted November 26, 2008 or just get the tach signal from the gauge cluster Link to comment Share on other sites More sharing options...
987687 Posted November 26, 2008 Share Posted November 26, 2008 or just get the tach signal from the gauge cluster My friend and I installed one it has baja, we got the tach signal from the gauge cluster and it worked fine. Link to comment Share on other sites More sharing options...
myth Posted November 26, 2008 Author Share Posted November 26, 2008 Removing the TMIC will give you access to a giant grommet. See pictures here http://www.legacygt.com/forums/showpost.php?p=2101962&postcount=130 eta: nevermind I see it's a 2002 your working on. Probably not the same. I used a rubber grommet. Put a wire through it and plug the grommet again. But it does not fit again. Thanks. Link to comment Share on other sites More sharing options...
