SayingSorry1988 Posted November 18, 2008 Share Posted November 18, 2008 is it worth fixing or replacing the motor? the motor has around 93.xxx its in a 99 legacy gt 2.5 Link to comment Share on other sites More sharing options...
SayingSorry1988 Posted November 19, 2008 Author Share Posted November 19, 2008 ANY idea? o.o Link to comment Share on other sites More sharing options...
aigochamaloh Posted November 19, 2008 Share Posted November 19, 2008 Is that a SOHC? I've seen a head that was pulled with bent valves, and from both sides, only 1 valve wasn't bent, the others were all bent from slight to extreme. So factor in buying valves, and machine shop work on getting them put in if you're not doing them yourself. Valves run anywhere from 10-20 each I think. Link to comment Share on other sites More sharing options...
SayingSorry1988 Posted November 19, 2008 Author Share Posted November 19, 2008 i think it is are valves easy to do? or am i better off paying sumone to do it Link to comment Share on other sites More sharing options...
BoozeRS05 Posted November 19, 2008 Share Posted November 19, 2008 Swap it.. EB's Subaru journal - 2005 LegacyGT Wagon & 2014 Forester FB25 (2008 specB - RIP) IG@legacygtliving Link to comment Share on other sites More sharing options...
SayingSorry1988 Posted November 20, 2008 Author Share Posted November 20, 2008 i am i just found out its around $1200 to do a valve job why just just swap the motor with lower miles mhm Link to comment Share on other sites More sharing options...
