NEPA Posted November 17, 2008 Share Posted November 17, 2008 Anyone know how much space there is behind the cubby? Thinking of a mod that would require cutting the back of the cubby out and it requires 2 to 4 inches of open space behind this area. Thanks. Link to comment Share on other sites More sharing options...
RochNY91TSI Posted November 17, 2008 Share Posted November 17, 2008 From memory, there's not much. I recall there being either a metal tube or beam within a couple of inches behind the back of the cubby Link to comment Share on other sites More sharing options...
RustyShackleford Posted November 17, 2008 Share Posted November 17, 2008 Speaking of which, since it looks like Highline is never really gonna come through with his low-cost after-market kit for cars with auto climate ... Can someone outline the process, and level of difficulty, for installing an aftermarket HU in the cubby ? I gather you first relocate the "info panel" using a bracket available from a3rd-party vendor; how hard is this ? Then exactly how do you trim out the new HU into the cubby area, and is it pretty easy to get the wiring to it ? Thanks ! Link to comment Share on other sites More sharing options...
BobsYourUncle Posted November 17, 2008 Share Posted November 17, 2008 From memory, there's not much. I recall there being either a metal tube or beam within a couple of inches behind the back of the cubby Off topic, but was that the auto cross track at RIT in your sig? Link to comment Share on other sites More sharing options...
nemo Posted November 17, 2008 Share Posted November 17, 2008 There's a little bit of room back there, not ALOT, but a little. However you could just yank out the cubby and measure. It would probably be your best bet so you can see how much room you have to work with. If you don't vote Trump, out, you're a bigot who hates america. Link to comment Share on other sites More sharing options...
fweasel Posted November 18, 2008 Share Posted November 18, 2008 There's a little bit of room back there, not ALOT, but a little. However you could just yank out the cubby and measure. It would probably be your best bet so you can see how much room you have to work with. 2nd, pull out the cubby and start measuring. To fit my double din in that location, a fair amount of plastic needed to be trimmed away from an HAVC plenum, in addition to the obvious dash supports that need to be 86'd. If whatever you're installing is deep enough, you'll get more clearance by going up and over the crash beam that runs through that space. ignore him, he'll go away. Link to comment Share on other sites More sharing options...
NEPA Posted November 18, 2008 Author Share Posted November 18, 2008 Thanks for the info. Looks like my best bet is pull it out and measure. Link to comment Share on other sites More sharing options...
gershon Posted November 18, 2008 Share Posted November 18, 2008 There is a good amount of space behind the cubby but the problem is that there is a plastic cross piece that spits the space in half. I cut the plastic support out and have not run into any issues as of yet and I did this last winter. I was able to fit two aux power ports into the back of my cubby. http://i64.photobucket.com/albums/h163/gershon23/IMG_0610.jpg Link to comment Share on other sites More sharing options...
RochNY91TSI Posted November 18, 2008 Share Posted November 18, 2008 Off topic, but was that the auto cross track at RIT in your sig? Yep, that's RIT Link to comment Share on other sites More sharing options...
