AGR-LGT Posted November 6, 2008 Share Posted November 6, 2008 Has anyoen else devised a better way to mount the AVO pod...the sticking to the a pillar is pretty weak sauce...anyone else done it differently?? thanks for the input Link to comment Share on other sites More sharing options...
rtbrjason Posted April 3, 2009 Share Posted April 3, 2009 I'm pretty disappointed with mine as well. Just got it and have tried several kinds of tap including moulding tape and it just doesn't hold to the a-pillar. The textured surface is just not working. I'm debating a tab of super glue Link to comment Share on other sites More sharing options...
TPLGT Posted April 3, 2009 Share Posted April 3, 2009 Mine has been on now for almost 2 years (I bot the pod, used) I think we used some 3m double sided tape. The thing has never moved....you should be OK with a methid such as this. GL Rehab is for quitters. Link to comment Share on other sites More sharing options...
rtbrjason Posted April 3, 2009 Share Posted April 3, 2009 Does the 06 have the same a-pillar? It's textured to the point where nothing it sticking to it. I've cleaned it thoroughly with alcohol before each try, and have tried 3 different kinds of double sided tape now. The moulding tape should be about the strongest there is, and it's just not holding to the a-pillar. Very frustrating to hear it start rattling then sliding around up there while driving. Link to comment Share on other sites More sharing options...
TPLGT Posted April 3, 2009 Share Posted April 3, 2009 The 06 has material on the A-Pillar...it would not stick thoroughly but enough so it never moves. How a bout some on the bottom of it? Maybe rig some form of 'bracket'...I will look at mine and get back to you. Rehab is for quitters. Link to comment Share on other sites More sharing options...
fonts Posted April 3, 2009 Share Posted April 3, 2009 Double or triple A pillar guage pod????? There is a member here who was selling them. He certainly makes a great product. Link to comment Share on other sites More sharing options...
frkkevin Posted April 4, 2009 Share Posted April 4, 2009 Does the 06 have the same a-pillar? It's textured to the point where nothing it sticking to it. I've cleaned it thoroughly with alcohol before each try, and have tried 3 different kinds of double sided tape now. The moulding tape should be about the strongest there is, and it's just not holding to the a-pillar. Very frustrating to hear it start rattling then sliding around up there while driving. Is it not sticking to the pod or the dash/pillar? If its the pod itself lightly sand it.. 3m double stick tape should hold it fine. Other options would be a custom A-pillar pod.. or just a cubby pod or perrin mount for the top of the steering column. 512whp/465ftlb 2005 5EAT Legacy (Build Log) Videos - - Link to comment Share on other sites More sharing options...
zmarko Posted April 4, 2009 Share Posted April 4, 2009 Double or triple A pillar guage pod????? There is a member here who was selling them. He certainly makes a great product. I believe the AVO pod they're talking about is the single one that sits at the base of the A-pillar, and basically lays on the dash and "sticks" to the A-pillar. Like this one (this is DoubleB's car). Link to comment Share on other sites More sharing options...
fonts Posted April 5, 2009 Share Posted April 5, 2009 I believe the AVO pod they're talking about is the single one that sits at the base of the A-pillar, and basically lays on the dash and "sticks" to the A-pillar. Like this one (this is DoubleB's car). I'm aware of the AVO pod. When I re-read my post it is obviously unclear what I was trying to say. Link to comment Share on other sites More sharing options...
RIPjeep2002 Posted April 5, 2009 Share Posted April 5, 2009 I am using 3m double sided sticky tape with velcro. its the sticky then the one side velro then the other then the sticky. its stuck amazing Link to comment Share on other sites More sharing options...
rtbrjason Posted April 5, 2009 Share Posted April 5, 2009 Is it not sticking to the pod or the dash/pillar? If its the pod itself lightly sand it.. 3m double stick tape should hold it fine. Other options would be a custom A-pillar pod.. or just a cubby pod or perrin mount for the top of the steering column. All 3 tapes i've tried stick like glue to the pod itself. None of them will stick well to the A-pillar due to the texture on the pillar. I used a dab of superglue on the tape and so far it is holding to the pillar, but it's only been a day. Link to comment Share on other sites More sharing options...
