dga Posted November 4, 2008 Share Posted November 4, 2008 I have this interesting problem when the HVAC is set to defrost. 1/2 of the upper defroster vent, the one on top of the dash, blows hot (driver side) and the other 1/2 blows cold (passenger side). This is with both of the climate control temperatures set to 65 degrees. This also only happens on defrost, every other setting works as it should. Does anyone have this problem? Would someone mind checking on their car with auto-climate control if they have the same results? Thanks, Drazen Link to comment Share on other sites More sharing options...
krzyss Posted November 5, 2008 Share Posted November 5, 2008 My HVAC (aka HAL) blows warm air when set to defrost. I did not check passenger side but driver side is definately warm. Krzys Link to comment Share on other sites More sharing options...
dga Posted November 5, 2008 Author Share Posted November 5, 2008 My HVAC (aka HAL) blows warm air when set to defrost. I did not check passenger side but driver side is definately warm. Krzys Thanks. I hope this is not normal. I like it cold and rolling with the window down because it gets too hot inside, in the rain, is not fun. Link to comment Share on other sites More sharing options...
