masterxtech Posted November 2, 2008 Share Posted November 2, 2008 ok so i just got a cobb ap1 and married it to my car... everything seemed to go smoothly so i turned off my car... then unplugged everything... car wont start it just turns over and keeps turning over... i try to reconnect the ap to reset back to stock... now its giving me a connection failed try agian... the er hc is still showing up on the odometer... and the temp gauge is still showing hot... wat do i do? anyone please help Link to comment Share on other sites More sharing options...
Regal05LGT Posted November 2, 2008 Share Posted November 2, 2008 Did you flash the base map and then the real time map? The green connectors are unplugged? Link to comment Share on other sites More sharing options...
NSFW Posted November 2, 2008 Share Posted November 2, 2008 The green connectors are unplugged? That's the first thing I'd check, too. Link to comment Share on other sites More sharing options...
masterxtech Posted November 2, 2008 Author Share Posted November 2, 2008 i flashed the base map... but when i turned it all off and disconnected all off then i tried turning on the car it would just turn over... thought the power might be low tried jumping it no go either... did a hard reset no go either... green wires are apart... it keeps saying error cannot connect... or try again Link to comment Share on other sites More sharing options...
Guntrain Posted November 2, 2008 Share Posted November 2, 2008 Did u try contacting cobb? thats the 2nd thing i'd do after checking the test connectors. Link to comment Share on other sites More sharing options...
masterxtech Posted November 2, 2008 Author Share Posted November 2, 2008 they are closed today Link to comment Share on other sites More sharing options...
05pearl Posted November 2, 2008 Share Posted November 2, 2008 I don't know about cobb, but when I reflash using ecutek, i have to reset the ecu after the reflash or the car will not start. Link to comment Share on other sites More sharing options...
masterxtech Posted November 2, 2008 Author Share Posted November 2, 2008 i tried a hard reset 3 times each time waited an hour... Link to comment Share on other sites More sharing options...
masterxtech Posted November 2, 2008 Author Share Posted November 2, 2008 can anyone help me? did i fry my ecu? Link to comment Share on other sites More sharing options...
masterxtech Posted November 2, 2008 Author Share Posted November 2, 2008 guess no one can help... ive been reading through the forums... ima give cobb a call tommorow... but i think im sol... and need to buy a new ecu... if anyone has one please pm me Link to comment Share on other sites More sharing options...
Guntrain Posted November 2, 2008 Share Posted November 2, 2008 Keep us updated, im curious myself as to whats wrong Link to comment Share on other sites More sharing options...
05pearl Posted November 2, 2008 Share Posted November 2, 2008 Ok, this will probably not help you, as I am not using Cobb. But, at this point maybe worth asking; Did you turn the car off for at least 10 seconds after the reset before trying to start the car? This is step by step what I do: 1. reflash the ecu 2. disconnect green plugs 3. reset ecu 3. turn car off and wait 10-20 seconds 4. start car Link to comment Share on other sites More sharing options...
z28dreams Posted November 2, 2008 Share Posted November 2, 2008 After your first flash, did you give it enough time? Immediately after a flash, if you try to start your car it will just crank but not turn over.The ECU is essentially "rebooting" with the new firmware. I just did the following:1. Flash new maps2. Turn car to off position3. Turn car to 'ON' (not START) position4. Wait 30 seconds5. Turn car to OFF6. Start car Link to comment Share on other sites More sharing options...
mwiener2 Posted November 2, 2008 Share Posted November 2, 2008 ^^ you only have to wait about 10 sec, not 30 OP, what year car do you have? My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
Legend Posted November 3, 2008 Share Posted November 3, 2008 Hopefully it doesn't come to this, but you might be able to overnight your ECU to Cobb. When I bought my '05, the previous owner had accidentally put a stock '06 rom on my ecu. It ran fine except for cruise control but more importantly it prevented any access to the ecu (via Cobb programming, open source and the dealership). I overnighted it to Cobb and they cleaned the corruption and put the correct factory rom on my ecu and they overnighted it back. They didn't even charge me to do it. My '05 LGT My '07 Supercharged Shelby Link to comment Share on other sites More sharing options...
masterxtech Posted November 3, 2008 Author Share Posted November 3, 2008 yea im planning on calling cobb tommorow... but yea i sat there all day trying to figure out how to start it...no luck... but i think its something with the ecu... cuse the ap wont connect to the ecu after the initial flash... i have a LGT 05 mt... i have ap1 its specific for the 05 mt Link to comment Share on other sites More sharing options...
masterxtech Posted November 3, 2008 Author Share Posted November 3, 2008 ok... ive tried to get a hold of cobb all day... and still nothing \=( Link to comment Share on other sites More sharing options...
jamiesong Posted November 3, 2008 Share Posted November 3, 2008 Sounds like something went wrong when you flashed it. How did you try to get a hold of cobb? If you emailed, I would try phone. They should still be open now. Link to comment Share on other sites More sharing options...
masterxtech Posted November 3, 2008 Author Share Posted November 3, 2008 finally i got someone to pick up... they said they gota have thier engineers think of a way to solve it... they said worse case scenario is i gota send it to them... and they will do what it takes to fix it =) Link to comment Share on other sites More sharing options...
masterxtech Posted November 3, 2008 Author Share Posted November 3, 2008 oh quick question for everyone wheres the ecu located? Link to comment Share on other sites More sharing options...
Regal05LGT Posted November 3, 2008 Share Posted November 3, 2008 Passenger side footwell Link to comment Share on other sites More sharing options...
masterxtech Posted November 3, 2008 Author Share Posted November 3, 2008 thanks... im not used to it being inside my car... my last car 91 mr2 had the ecu in the trunk Link to comment Share on other sites More sharing options...
masterxtech Posted November 5, 2008 Author Share Posted November 5, 2008 okay well cobb had me send it in... just gota wait on that now... im curious tho now that i pulled out my ecu... i have 2 sets of connectors that sad next to the wires to the ecu... they werent hooked up to anything... anyone know what they are for? Link to comment Share on other sites More sharing options...
taskforcefreddy Posted November 5, 2008 Share Posted November 5, 2008 I had something similar the very same day I was getting on the plane to fly to Iraq. I f'ed up the reflash of a new E-Tune... was totally my fault and the car would not start. I was literally crapping myself as I was running out of time. As a last resort, I ended up trying "Revert Back to Stock" as I already had a tune in the car. After reverting back, I started the car, and it fired right up. Link to comment Share on other sites More sharing options...
mwiener2 Posted November 5, 2008 Share Posted November 5, 2008 anyone know what they are for? one set (green) is the test mode connector. I'm not sure what the second set is My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
