FLEXN LegacyGT Posted November 2, 2008 Share Posted November 2, 2008 I will use this post as my introduction to the community... 06 LGTL StageII (previously owned by a member) Nothing new with this mounting solution, just a clean way to do it. Here's my version(quick summary) of the boost gauge mounted to the steering column. The set up: STRI DSD electronic boost gauge 52mm, white LED Glowshift swivel pod (base removed) miscellaneous hardware, and 4 hours of work... Pic at the bottom shows how the pod is mounted and where the Warning/Peak Boost control was mounted to the control unit below to the dimmer switch. (Video shows me recal last peak in boost) [ame=http://www.youtube.com/watch?v=yVBJTo-2Cvo]YouTube - STRI Boost 2[/ame] [ame=http://www.youtube.com/watch?v=dpecLLgu310]YouTube - Legacy STRI Boost[/ame] Link to comment Share on other sites More sharing options...
FLEXN LegacyGT Posted November 6, 2008 Author Share Posted November 6, 2008 Where else have those with the STRI DSD series mounted the peak boost recall/ warning button? Link to comment Share on other sites More sharing options...
hogmeat Posted January 3, 2009 Share Posted January 3, 2009 Dude...you didn't get any replies because you are not teh Hogmeat. lols, just had to look you up and check on my car. Why no video's when you are DRIVING??! That's what people want to see. Give 'em what they want! If I can drive, shift, and film, so can you! I'm pleasantly surprised... It was most certainly worth the couple bucks and 10 mins of my time. CLICK HERE FOR THE HOGZAUST Link to comment Share on other sites More sharing options...
FLEXN LegacyGT Posted February 3, 2009 Author Share Posted February 3, 2009 http://legacygt.com/forums/showthread.php?t=104759 Link to comment Share on other sites More sharing options...
