greenleg88 Posted October 29, 2008 Share Posted October 29, 2008 hokay so. in a 97 legacy L sedan the keyless system = ultra start G11t The wiring diagram from factory: http://img136.imageshack.us/img136/2...img0904zj8.jpg with a Change: http://img373.imageshack.us/img373/2...img0907gp9.jpg my wiring diagram resources: http://www.angelfire.com/fang/doofus...less/99leg.pdf http://www.angelfire.com/fang/doofus...6-97legacy.pdf http://www.angelfire.com/fang/doofus...7-99legacy.pdf http://www.angelfire.com/fang/doofus...s/97legacy.pdf The Problem I cant find the wires for: horn (-) different resources say different things. two say it is red/green and from a 3 pin black plug and two sources say red/blue wire @ horn relay or keyless module (obviously this doesnt exist) Parking light (-) it says to look for in headlight switch.... and should be black/green idk where to look.... othere than taking the steering wheel covers off... is that really what i need to do...? What is a ground while running output? (pin 12) and where would i find that... please help confirm.. Parking light (+) im not entirely sure. but i do believe i have found it. is this it? does it come out of the plug immediately above the fuse box towards the rear of the car. (that fits the description of red with silver dots in gray connector above fuse box) one source says to look next to ignition harness for that color wire.. so is the wire thats pulled out from the rest of the wires coming out of that molex possibly the one i need..? (i know its not clear.. sorry) http://img373.imageshack.us/img373/9...img0897bk4.jpg Brake switch input (+) the white one on the right right? http://img373.imageshack.us/img373/7052/img0901aq3.jpg please advise: im guessing i can just leave the following wires unwired.. pin 1: diesel wait to start input pin 7: tach detection input (optional anyway and recommended to wire without unless car takes more than 2 seconds of cranking to start) pin 8 & 10: re arm and dis arm outputs: i dont have an alarm... so can i leave that blank? pin 9: no trunk release... http://img136.imageshack.us/img136/2...img0904zj8.jpg thank you thankyou thank you for responses! Link to comment Share on other sites More sharing options...
