greenleg88 Posted October 29, 2008 Posted October 29, 2008 hokay so. in a 97 legacy L sedan the keyless system = ultra start G11t The wiring diagram from factory: http://img136.imageshack.us/img136/2789/diagramimg0904zj8.jpg with a Change: http://img373.imageshack.us/img373/2633/changeimg0907gp9.jpg my wiring diagram resources: http://www.angelfire.com/fang/doofusboy9/Keyless/99leg.pdf http://www.angelfire.com/fang/doofusboy9/Keyless/96-97legacy.pdf http://www.angelfire.com/fang/doofusboy9/Keyless/97-99legacy.pdf http://www.angelfire.com/fang/doofusboy9/Keyless/97legacy.pdf The Problem I cant find the wires for: horn (-) different resources say different things. two say it is red/green and from a 3 pin black plug and two sources say red/blue wire @ horn relay or keyless module (obviously this doesnt exist) Parking light (-) it says to look for in headlight switch.... and should be black/green idk where to look.... othere than taking the steering wheel covers off... is that really what i need to do...? What is a ground while running output? (pin 12) and where would i find that... please help confirm.. Parking light (+) im not entirely sure. but i do believe i have found it. is this it? does it come out of the plug immediately above the fuse box towards the rear of the car. (that fits the description of red with silver dots in gray connector above fuse box) one source says to look next to ignition harness for that color wire.. so is the wire thats pulled out from the rest of the wires coming out of that molex possibly the one i need..? (i know its not clear.. sorry) http://img373.imageshack.us/img373/9625/parklightimg0897bk4.jpg Brake switch input (+) the white one on the right right? http://img373.imageshack.us/img373/7052/img0901aq3.jpg please advise: im guessing i can just leave the following wires unwired.. pin 1: diesel wait to start input pin 7: tach detection input (optional anyway and recommended to wire without unless car takes more than 2 seconds of cranking to start) pin 8 & 10: re arm and dis arm outputs: i dont have an alarm... so can i leave that blank? pin 9: no trunk release... http://img136.imageshack.us/img136/2789/diagramimg0904zj8.jpg thank you thankyou thank you for responses!
greenleg88 Posted October 31, 2008 Author Posted October 31, 2008 i just finished wiring the keyless entry on my car.. but theres the remote start bit that i cant finish.. i tried setting it up without hooking up the tach... but the starter doesnt seem to like that... and is saying tach lock out. so i guess ill have to hook it up and give it a shot. where is the ignition coil... i dont really know what to be looking for.. other than a blue wire.. please advise. Thanks! ALSO.... why is systems horn output (-) ? that doesnt make any sense to me.. if the horn is grounded negative.. why would it output negative as well.. btw.. i couldnt find the horn wire still... so i didnt hook it up.. but i checked it.. and the output is only liek - .4 volts output.. which is strange.. i was expecting the full 12..
SubieLegacy04 Posted December 7, 2008 Posted December 7, 2008 Heya, I just installed an Ultra Start in my 04 Legacy so I might be able to help you out a bit here. I have access to ARRC files for any year subaru too so I can tell you the correct color wires at the very least First off the horn wire for your car that you should be looking for would be RED/GRN. That is the wire that goes from your steering wheel to the fuse relay box. The red/blue you spoke of is the wire that goes from the actual horn to the fuse box. So technically both sources were correct, but the red/grn is the one you want. The tach wire is the BLK/BLUE wire and I think you can access it either at the ignition coil or possibly at your ECU? Don't quote me on that location. I connected to mine directly at my ECU which was under the glove compartment, under the rug; but I've got a different year lgt. I do know that you should be looking for a BLK/BLUE wire though according to the wiring diagram. I'm assuming that you found the BLK/GRN wire for the parking lights so I'll leave it at that. I hope that helps! Good luck!
