silver03 Posted October 25, 2008 Share Posted October 25, 2008 I need to replace struts on a 92 AWD Legacy LS sedan I just acquired. What else (impreza, later year legacy) would use the same struts? thanks Link to comment Share on other sites More sharing options...
Bdubs Posted October 25, 2008 Share Posted October 25, 2008 GC/GM/GF Impreza, from 93-01 will bolt right up, but you will need front spring perches off a GC as well. 95-99 BD/BG Legacy will work, also needing only the front top perches. Link to comment Share on other sites More sharing options...
silver03 Posted October 26, 2008 Author Share Posted October 26, 2008 thank you thank you thank you Link to comment Share on other sites More sharing options...
silver03 Posted October 27, 2008 Author Share Posted October 27, 2008 spring perch=tophat? So if I found 00 impreza struts/front tophats...good to go? Link to comment Share on other sites More sharing options...
Bdubs Posted October 27, 2008 Share Posted October 27, 2008 You would be good to go if you have the complete tophat. The perch is just what goes underneath that tophat, which enables the spring to seat correctly with the strut. Link to comment Share on other sites More sharing options...
