Denver133 Posted October 23, 2008 Share Posted October 23, 2008 I have been shopping for a set of front brembo sti calipers to do a swap. I can not find an install at all. I did see a few people talking about a link to theL7 but that site does not work any more. Anyone have a step by step laying around? Link to comment Share on other sites More sharing options...
FASTONE Posted October 27, 2008 Share Posted October 27, 2008 not to steal you thread, but will the front sti calipers from 04 or otherwise fit stock LGT rotors, or you HAVE YO USE sti rotors. Link to comment Share on other sites More sharing options...
Denver133 Posted November 2, 2008 Author Share Posted November 2, 2008 I am 100% sure you need sti specific rotors. Link to comment Share on other sites More sharing options...
ordiga Posted November 3, 2008 Share Posted November 3, 2008 And it has to be the first year of the STI because those have the same lug pattern as the Legacy's. The newer sti's (05 and up i think) use a 5x114.3 lug pattern.... Link to comment Share on other sites More sharing options...
lawl Posted November 4, 2008 Share Posted November 4, 2008 denver from san diego, i am in san diego, and i have full sti brembos. if you wanna check them out before you dive in give me a PM. car for sale. PM me! Link to comment Share on other sites More sharing options...
fweasel Posted November 4, 2008 Share Posted November 4, 2008 I have been shopping for a set of front brembo sti calipers to do a swap. I can not find an install at all. I did see a few people talking about a link to theL7 but that site does not work any more. Anyone have a step by step laying around? You don't need one if you are familiar with working on brakes, its very straight forward. If not, I highly suggest having someone on hand who does have brake experience. And another quick note, search for my post on the proper torque specs for the front caliper mounting bolts. I'm too lazy to find it myself. ignore him, he'll go away. Link to comment Share on other sites More sharing options...
lawl Posted November 4, 2008 Share Posted November 4, 2008 You don't need one if you are familiar with working on brakes, its very straight forward. If not, I highly suggest having someone on hand who does have brake experience. And another quick note, search for my post on the proper torque specs for the front caliper mounting bolts. I'm too lazy to find it myself. + 1 are you getting this done yourself? cuz i know a guy. he's prettttty awesome! car for sale. PM me! Link to comment Share on other sites More sharing options...
Denver133 Posted November 7, 2008 Author Share Posted November 7, 2008 Thanks for the info guys. I was looking for the install to get an idea of what it is like on the legacy. Since I moved to SD I dont have a garage and can't do much in my "parking space" due to HOA issues. I found some fronts but I am looking for rears. Link to comment Share on other sites More sharing options...
lawl Posted November 13, 2008 Share Posted November 13, 2008 My garage is available. The rear I cannot do because no cutting tool and no dremel. But shoot me a PM. Ursine is coming over tonight to check out the setup. You're welcome as well. car for sale. PM me! Link to comment Share on other sites More sharing options...
Denver133 Posted November 14, 2008 Author Share Posted November 14, 2008 Lawl, Just saw this! I just sent you a pm. Not sure if you are free tonight. I need rims before I can throw on my front brembos and am looking for a pair in the rear. I am also thinking of painting Silver instead of the gold to give it a little more of that S402 look. Link to comment Share on other sites More sharing options...
Supra333 Posted November 17, 2008 Share Posted November 17, 2008 My garage is available. The rear I cannot do because no cutting tool and no dremel. But shoot me a PM. Ursine is coming over tonight to check out the setup. You're welcome as well. Just a question on that, what do u have to cut or modify on the rears to make them work? Link to comment Share on other sites More sharing options...
lawl Posted November 19, 2008 Share Posted November 19, 2008 Just a question on that, what do u have to cut or modify on the rears to make them work? heat shield- the new rotors are too big. u either have to bend the heat shield back or cut off the offending rim. there is a 1/4 inch section of an A arm or whatever that needs to be trimmed for a bolt. you'll see it when you try to put it on. we used a dremel and a carbide (sp?) head for the suspension trimming. used a small circular saw thing for the heat shield car for sale. PM me! Link to comment Share on other sites More sharing options...
Supra333 Posted November 19, 2008 Share Posted November 19, 2008 heat shield- the new rotors are too big. u either have to bend the heat shield back or cut off the offending rim. there is a 1/4 inch section of an A arm or whatever that needs to be trimmed for a bolt. you'll see it when you try to put it on. we used a dremel and a carbide (sp?) head for the suspension trimming. used a small circular saw thing for the heat shield Alright, thanks for the help Link to comment Share on other sites More sharing options...
Denver133 Posted November 19, 2008 Author Share Posted November 19, 2008 Well I got the write up from theL7 but I can't upload it. It is too large. I will probably do another thread with the walkthrough. Link to comment Share on other sites More sharing options...
praedet Posted November 20, 2008 Share Posted November 20, 2008 All you need to remove the heatshield in the rear is a flathead screwdriver/chisel and a hammer... Just bust the spot welds and bend it off Link to comment Share on other sites More sharing options...
WANTED Posted September 3, 2009 Share Posted September 3, 2009 Revived from the dead. Just to make sure I understand this correctly, the 03-04 STI brake calipers and rotors mate up with no issues other than needing to remove the rear heatshield? Link to comment Share on other sites More sharing options...
