NotMyGT Posted October 23, 2008 Share Posted October 23, 2008 Does anyone have Work CR-Kai's on their Legacy? If so, what size and tires are you running? I'm thinking for my own set I would go 18x8.5 with 245/35-18s for tires. I've done a fair bit of reading and searching, I haven't found anyone with this same setup. Link to comment Share on other sites More sharing options...
NotMyGT Posted October 24, 2008 Author Share Posted October 24, 2008 Ok, so I was searching a bit more for people with these sizes and it seems like they fit. However, I'm not sure if they were on coilovers, lowering springs or stock suspension. Anyone have an idea if they'll fit with stock suspension? Link to comment Share on other sites More sharing options...
a.lim Posted October 24, 2008 Share Posted October 24, 2008 i run 18x8.5 with 235/40/18 tires lowered on htechs and i dont rub. you should be fine.. Link to comment Share on other sites More sharing options...
NotMyGT Posted October 24, 2008 Author Share Posted October 24, 2008 i run 18x8.5 with 235/40/18 tires lowered on htechs and i dont rub. you should be fine.. What offset are you running? Link to comment Share on other sites More sharing options...
aussie_coyote Posted October 24, 2008 Share Posted October 24, 2008 I have 18x8.5 +46 with 235/40s, lowered 15mm in front and lifted 5mm in back. No rubbing whatsover. It's a wagon (of course). Link to comment Share on other sites More sharing options...
a.lim Posted October 24, 2008 Share Posted October 24, 2008 what offset are you running? +48 Link to comment Share on other sites More sharing options...
NotMyGT Posted October 24, 2008 Author Share Posted October 24, 2008 Do you guys think 245/35-18s would work with a wheel offset of +43? I'm thinking it would but no one has really confirmed it. Link to comment Share on other sites More sharing options...
HansGT Posted October 24, 2008 Share Posted October 24, 2008 Why not save a chunck of change and just get a set of rota torques? (18x8 +48) The look nearly identical. http://www.rotawheels.com/wheels.asp?wheelid=45 (Shown below in hyper black 17x8...18.6lbs.) Link to comment Share on other sites More sharing options...
NotMyGT Posted October 24, 2008 Author Share Posted October 24, 2008 Why not save a chunck of change and just get a set of rota torques? (18x8 +48) The look nearly identical. http://www.rotawheels.com/wheels.asp?wheelid=45 (Shown below in hyper black 17x8...18.6lbs.) I've always been picky about wheels and aftermarket parts. I don't really like doing knockoffs. Although most knockoffs have crap for quality. I'm not sure of the quality of the Rotas. How's the quality on the Rotas? Link to comment Share on other sites More sharing options...
HansGT Posted October 24, 2008 Share Posted October 24, 2008 IMO, outstanding for $650 a set (17x8). On mine I have two small imperfections. On the interior of one of the spokes you can see about a 1mm x 5mm line that is a little depressed in the metal. Only visible when your down at wheel level and REALLY looking for something. The other has a tiny bit of extra coating or material on the lip in between the lip and tire. It's like the inside section that is almost totally covered by the tire. You need to run your finger along it to tell. Again a small area. None of these are visible past 3 feet from the car and 99.9% of people would never see it. The weight isn't terrible either for a cast wheel. And they are pretty strong and Rota makes many OEM wheels for Japanese car manufactures. BTW...you can get remove the "R" rota label on the center cap if you want to hide the Rota name. Link to comment Share on other sites More sharing options...
HansGT Posted October 24, 2008 Share Posted October 24, 2008 http://www.wheeldude.com/wdg/view_newest.php?page=1&query=wheeltype%3DRota%20Torque Link to comment Share on other sites More sharing options...
NotMyGT Posted October 24, 2008 Author Share Posted October 24, 2008 IMO' date=' outstanding for $650 a set (17x8). On mine I have two small imperfections. On the interior of one of the spokes you can see about a 1mm x 5mm line that is a little depressed in the metal. Only visible when your down at wheel level and REALLY looking for something. The other has a tiny bit of extra coating or material on the lip in between the lip and tire. It's like the inside section that is almost totally covered by the tire. You need to run your finger along it to tell. Again a small area. None of these are visible past 3 feet from the car and 99.9% of people would never see it. The weight isn't terrible either for a cast wheel. And they are pretty strong and Rota makes many OEM wheels for Japanese car manufactures. BTW...you can get remove the "R" rota label on the center cap if you want to hide the Rota name.[/quote'] Thanks for all the good info. I'll definitely have to take a second look at Rotas. I was originally looking at the Tarmacs but I just didn't like the design of the spokes. The Torques look more my style, now if only the bronze looks right I might have to get the 18x8's. Thanks again for your help. Link to comment Share on other sites More sharing options...
axis008 Posted October 24, 2008 Share Posted October 24, 2008 Don't support the copies! The Emotions don't come in 18x8.5" +43 in 5x100 (Legacy) bolt pattern, only 5x114.3 (non-Legacy). There are Emotion XT7's that come in 18x8.5" +46, Emotion XD9's that come in 18x8.0" +45, and Emotion XC8's that come in 18x8.5" +47 that will work with your car though. And FWIW, the OEM comment applies to the Philippines only, where Rotas are made. -ben Link to comment Share on other sites More sharing options...
HansGT Posted October 24, 2008 Share Posted October 24, 2008 ^ I thought they made OEM wheels for Honda and Toyota??? FWIW, they're hard to be beat for the price. I don't regret my purchase one bit. Link to comment Share on other sites More sharing options...
NotMyGT Posted October 24, 2008 Author Share Posted October 24, 2008 Don't support the copies! The Emotions don't come in 18x8.5" +43 in 5x100 (Legacy) bolt pattern, only 5x114.3 (non-Legacy). There are Emotion XT7's that come in 18x8.5" +46, Emotion XD9's that come in 18x8.0" +45, and Emotion XC8's that come in 18x8.5" +47 that will work with your car though. And FWIW, the OEM comment applies to the Philippines only, where Rotas are made. See, that's my thinking. Thank you for correcting me on the offsets with bolt patterns. The XC8s remind me of STi wheels and the XD9 I had my eye on as well. I still want to know how well and if at all 245/35-18s work on stock suspension because eventually I'll be going to coilovers and I know it will work then. Maybe I should do reverse order, coilovers and then wheels/tires. Link to comment Share on other sites More sharing options...
