LittleBlueGT Posted October 22, 2008 Share Posted October 22, 2008 How cool is this, not that I made it up or anything: From the COBB forums, I guess the odd good does come from that forum: I've written a java program that will convert the timestamps of all .csv files in the current directory To use: 1. Back up all your log files in case there is a bug in my program 2. Make sure you have java installed (http://java.com/en/download/installed.jsp?detect=jre&try=1) 3. Download timestamps.jar (http://206.176.232.253/timestamps.jar) 4. Place timestamps.jar in the folder where your .csv log files are stored 5. Double click on timestamps.jar to execute 6. verify that all the timestamps in the log files were successfully converted 7. verify that the converted log files work properly with the road dyno spreadsheet 8. Let me know if it works for you 9. Re-run timestamps.jar anytime that you add new logs to the folder and wish to have their timestamps converted Now you can use your ST logs to in the accel function in Airboy's sheet! Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
Spec B Posted October 23, 2008 Share Posted October 23, 2008 What does this mean? Link to comment Share on other sites More sharing options...
LittleBlueGT Posted October 23, 2008 Author Share Posted October 23, 2008 You can now more fully use your ST log files in airboy's sheet. It converts he time stamp in ST logs to simple ms. Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
stiinc Posted October 23, 2008 Share Posted October 23, 2008 Good job as usual, LBGT. Link to comment Share on other sites More sharing options...
