silver03 Posted October 12, 2008 Share Posted October 12, 2008 I just picked up a set of 17" Audi Borbet wheels in excellant condition with nearly new Dunlop M3 wintersports, 225/45/17 for cheap. The wheels look to be 7.5 inch with an offset of +38, 5x100. I put a back one just to see and I am maybe outside the fendor by an 1/8". I am running a stock spring/strut on my 05 LGT. Okay to run with? or should I just have the tires mounted on my stockers? Thanks Link to comment Share on other sites More sharing options...
rurouni_x Posted October 12, 2008 Share Posted October 12, 2008 38 offset is fine with stock suspension. Link to comment Share on other sites More sharing options...
str8dwn Posted October 12, 2008 Share Posted October 12, 2008 The inner (suspension) side should be fine with the low offset. However, because they are so far out toward the fender, it may cause premature wear on your wheel bearings. If you're cool with that, go for it. Link to comment Share on other sites More sharing options...
