RaGe Posted October 3, 2008 Share Posted October 3, 2008 Well, i finished up this install last night. There is another thread detailing the install, but the pictures are no longer available, so i figured i would just snap some photos of mine for referencing. I will try to get a list of what was purchased, but i cant remember everything. First off, the hellas. They come red. But i didnt want red, so i painted mine black. http://i72.photobucket.com/albums/i171/Crucifix79/hella%20install/hellainstall002.jpg I then made a bracket. I had some extra parts of stuff laying around so i just used it. but the piece of flat steel was purchased from lowes for like 4 bucks. it is like 1" wide, and comes in 4'. This bracket you can make any size you want. I think mine ended up being around 10" long. http://i72.photobucket.com/albums/i171/Crucifix79/hella%20install/hellainstall003.jpg But i centered it on the hood latch and made sure nothing would hit, centering up everything. I then just drill the 3 holes into the bracket. 2 for the horns and 1 for the mounting bolt. The below picture is the bolt in which i used. It is a 12mm. http://i72.photobucket.com/albums/i171/Crucifix79/hella%20install/hellainstall001.jpg This is a thread that i also used. http://forums.nasioc.com/forums/showthread.php?t=1133994&highlight=supertones In this thread you will notice a jumper wire ( Y wires ). I ended up making 3 of these. 1 for the stock horns. And 2 for the hellas ( 1 positive, and 1 negative ). see picture. Female connectors was used at the end of the wires minus the vampire clip at the Y's. http://i72.photobucket.com/albums/i171/Crucifix79/hella%20install/hellainstall004.jpg 14 Gauge wire ( black ) msc male/female connectors. In line fuse 20A fuse for the inline. what i done. * remove the negative connection from the battery. ( i didnt ) *Remove the grill. *i removed the air intake to obtain decent pictures and to just make my wiring a little easier but you dont have to do this. *remove the fender well. I believe it is held on by 3 grommets/ pop-its. Pull it back to be able to access the stock horns. ( forgot to get a picture of that ). * Un hook the Stock horn wires from the horn itself. On this step, instead of snipping off the factory connector, i just used a male connector and plugged them in, in case i wanted to go back to stock horns. I used the jumper ( Y ) wire i made and ran those wires to where i was going to mount the relay. * i then mounted my hellas with the bracket i made. hooked up the jumper wires ( 1 jumper for positive, and 1 for negative. ). I gave myself plenty of extra wire so that way i could hide and route the wire anywhere i wanted. * I determined the amount of wire needed for the ground for the hellas and routed the wire to the grounding location in which i would be using. I chose to use the frame as the ground. ( passenger side frame rail ) http://i72.photobucket.com/albums/i171/Crucifix79/hella%20install/hellainstall010.jpg http://i72.photobucket.com/albums/i171/Crucifix79/hella%20install/hellainstall009.jpg * I then ran the positive wires from the hellas to the relay location. Also using the jumper wire that i made. * i then ran the ground wire for the relay. I used the bolt that is located right behind the engine fuse box. This bolt is 10mm. Ran the wire to the relay. http://i72.photobucket.com/albums/i171/Crucifix79/hella%20install/hellainstall011.jpg * Then the inline fuse was ran from the battery to the relay. I had to extend it so i picked up some heavier gauged wire to match the in-line fuse wire. But, the wire is ran to the relay location. If you have not done so already, remove the fuse that is in the inline. * I then mounted the relay. i chose an easy spot to mount this. I did not want wires running from here to there, so i just picked a neutral location and put it there which was beside the washer fluid resevoir. A self tapping screw was used. * At this time i hooked up all the wires to the specific spots/ports have you. here is a quick cheat guide. 30-positive ( inline fuse ) 85-Relay ground. 86-stock horns 87-positive connection for the hella supertones. Place the 20 amp fuse in the inline fuse holder, and test the horns. This was my personal choice, but i wire loomed and zip tied everything. to dress it up and to clean up the work to give it a little bit more of a proffesional look. Like i said, tried. http://i72.photobucket.com/albums/i171/Crucifix79/hella%20install/hellainstall007.jpg And the finished product. http://i72.photobucket.com/albums/i171/Crucifix79/hella%20install/hellainstall005.jpg Here is the audio / video. [ame=http://es.youtube.com/watch?v=XFstcxQ2gpk]YouTube - Hella Super Tones[/ame] OTM. Sorry I didn't mean to start a war which mainly forum people is all about . Link to comment Share on other sites More sharing options...
nemo Posted October 3, 2008 Share Posted October 3, 2008 Nice write-up. I hate the sound of the stock horns. If you don't vote Trump, out, you're a bigot who hates america. Link to comment Share on other sites More sharing options...
Dergara Posted October 3, 2008 Share Posted October 3, 2008 Nice pics, thanks “Abandon hope, all ye who enter here” -Dante Alighieri http://youtu.be/lLFunBPgPOo Link to comment Share on other sites More sharing options...
Mitch Posted October 3, 2008 Share Posted October 3, 2008 Great Walk-through. You'll love em. If I'm going faster than you, Move Right. Link to comment Share on other sites More sharing options...
mccorry Posted October 3, 2008 Share Posted October 3, 2008 I need to do this sometime..... Link to comment Share on other sites More sharing options...
LegGTLT Posted October 3, 2008 Share Posted October 3, 2008 Wow. Really well done RaGe! Nice write up and the bracket looks friggin great! Please PM joeleodee For All Site Questions. He is the acting Admin and can resolve anything related to LegacyGT.com Link to comment Share on other sites More sharing options...
Detslider Posted October 4, 2008 Share Posted October 4, 2008 good job, very clean install. Link to comment Share on other sites More sharing options...
RaGe Posted October 4, 2008 Author Share Posted October 4, 2008 1st post updated with audio/video. OTM. Sorry I didn't mean to start a war which mainly forum people is all about . Link to comment Share on other sites More sharing options...
icegrill Posted October 6, 2008 Share Posted October 6, 2008 Has anyone done the supertones on an 08'+? It seems like the stock horns are in a different location. Thanks Link to comment Share on other sites More sharing options...
scoobydoobie Posted August 13, 2011 Share Posted August 13, 2011 Old thread.. any way to get the pics back up? Link to comment Share on other sites More sharing options...
tbperry Posted September 17, 2011 Share Posted September 17, 2011 ^ same question. interested in doing this but need to know how much is involved... Link to comment Share on other sites More sharing options...
ibr_adam09 Posted November 23, 2011 Share Posted November 23, 2011 Its all elementary wiring. Here's my sketch http://i344.photobucket.com/albums/p330/ibr_adam09/2005%20Legacy%20GT%20%20ABP/Hellawireinst.jpg Link to comment Share on other sites More sharing options...
BigTDogg MA Posted February 28, 2012 Share Posted February 28, 2012 Also: http://forums.nasioc.com/forums/showthread.php?t=1133994 Link to comment Share on other sites More sharing options...
