DarkLegacy Posted October 2, 2008 Share Posted October 2, 2008 How difficult is it to install the up pipe? I found some good installation guides on the forum.... but I was just wondering. Link to comment Share on other sites More sharing options...
rurouni_x Posted October 2, 2008 Share Posted October 2, 2008 it's pretty hard the first time. Just take it slow and do it right the first time. Link to comment Share on other sites More sharing options...
DarkLegacy Posted October 3, 2008 Author Share Posted October 3, 2008 Why is it difficult.... because there is alot involved or because parts are hard to reach, etc???? Link to comment Share on other sites More sharing options...
GTkansan Posted October 3, 2008 Share Posted October 3, 2008 Hard to reach, you need to first get the front end in the air, then (depending on how dexterous you are) need to jack the engine up a bit to get clearance to remove the UP to Turbo bolts (there are 5). Link to comment Share on other sites More sharing options...
DarkLegacy Posted October 3, 2008 Author Share Posted October 3, 2008 any suggestions on tools or supplies? Link to comment Share on other sites More sharing options...
DarkLegacy Posted October 3, 2008 Author Share Posted October 3, 2008 Lunchtime bump Link to comment Share on other sites More sharing options...
God help me Posted October 8, 2008 Share Posted October 8, 2008 i'm not really a good hands on guy and i did it with a buddy on my 06. Used simple hand tools and some PB BLaster for the bolts, also spray the gaskets with copper sealant.(just to be safe) Took about 5 hours though. i didn't have to jack the engine up or do anything special. Followed the guides on here and it went pretty smooth. Link to comment Share on other sites More sharing options...
DarkLegacy Posted October 8, 2008 Author Share Posted October 8, 2008 maybe i will try it again in the future... I was bought and up and down pipe and attempted to do the install myself. I took off the dp and that went ok... then I started to take off the up pipe and my lack of confidence got the better of me and I bailed. I just installed the downpipe and turbo heat shield and called it a day... I am not looking forward to taking off the down pipe and intercooler and all that stuff again... but i will have to do it someday. Link to comment Share on other sites More sharing options...
StoplightAssassin Posted October 8, 2008 Share Posted October 8, 2008 Taking off the intercooler and downpipe is easy...it's the up that's the PITA. I was able to do my up with out jacking up the engine...you just have to take off the bracket underneath the turbo. It took me two days by myself to get everything done with no exhaust leaks, but it was worth it...especially now with my PDX maps. Link to comment Share on other sites More sharing options...
05gtlimited300 Posted October 10, 2008 Share Posted October 10, 2008 u dont need to take off the intercooler. its easier but you can still work around the intercooler to remove the bolts for the downpipe. Link to comment Share on other sites More sharing options...
lucasmit Posted December 1, 2008 Share Posted December 1, 2008 its pretty hard to get the bolts holding the heat shield on without removing the intercooler. The intercooler is the easiest thing to remove. I got my dp installed and wimped on before I tried the up. it looks like a pita!! I really dont want to remove the manifold or jack up the engine. Link to comment Share on other sites More sharing options...
Ferenczy33 Posted December 1, 2008 Share Posted December 1, 2008 It is not a project for the timid. Definitely takes that committment to just go for it. I had my UP and pondered for a couple of weeks until I just had to say screw it and did it. If you take your time, and do everything in the right order, it is really not that bad with the right tools. If your confident doing your own brakes, and can manage a DP install, then you can do an UP install. It's just a little more tedious. Check out Post #174 http://www.legacygt.com/forums/showthread.php?t=5118&page=12 for a step-by-step list of the process. Link to comment Share on other sites More sharing options...
mikeislord Posted December 2, 2008 Share Posted December 2, 2008 Wow that really is a good write up! Link to comment Share on other sites More sharing options...
ama0787 Posted December 19, 2010 Share Posted December 19, 2010 I just did it for the second time was on here browsing for tips as I could not remember but just so you guys know I did it with out removing intercooler manifold of jacking up the motor. Thought I would mention that since lots of people seem to back out for those reasons. Link to comment Share on other sites More sharing options...
