07GTLEG Posted October 29, 2008 Author Share Posted October 29, 2008 it should have been factory installed not an option.i paid $48.it was weird i got the tan one.the black one was like $25 more than the tan. Link to comment Share on other sites More sharing options...
Mr. Sinister Posted October 29, 2008 Share Posted October 29, 2008 it should have been factory installed not an option.i paid $48.it was weird i got the tan one.the black one was like $25 more than the tan. Heh. I ordered the black one and got a tan one instead. I ended up just peeling the felt off. Link to comment Share on other sites More sharing options...
Guest thelosmos Posted October 29, 2008 Share Posted October 29, 2008 Whats the difference between the black and tan sensors? Link to comment Share on other sites More sharing options...
schneiks Posted October 29, 2008 Share Posted October 29, 2008 I've only had my shock sensor set off the alarm on one occasion when a colleague walked right into the driver's side mirror trying to go between cars. Link to comment Share on other sites More sharing options...
Guest thelosmos Posted October 29, 2008 Share Posted October 29, 2008 So searching the site i've figured out the part number is H711SAG000 for the sensor. Does anyone know if it is still the same part for the 2009's? Online I can find this thing for $50-$60, but the dealer wants $100. Link to comment Share on other sites More sharing options...
Mr. Sinister Posted October 29, 2008 Share Posted October 29, 2008 Whats the difference between the black and tan sensors? The tan one has tan felt covering it. The black one either has black felt or no felt. It's because the black one would really be noticeable on a tan colored interior. Link to comment Share on other sites More sharing options...
g2redgsr Posted October 30, 2008 Share Posted October 30, 2008 So all in all, about 100 dollors total for an ACTUAL alarm...i think i may go this route its a little extra security, if anyone wanted to break into my car right onw they would have no problem with no alarm...anyone install this in a 06 LGT? Link to comment Share on other sites More sharing options...
07GTLEG Posted October 31, 2008 Author Share Posted October 31, 2008 it should be the same as my wifes 07.it took less than 5 minutes. Link to comment Share on other sites More sharing options...
g2redgsr Posted October 31, 2008 Share Posted October 31, 2008 im just tossing it back and forth if its worth 100 bucks... Link to comment Share on other sites More sharing options...
Jon in CT Posted November 1, 2008 Share Posted November 1, 2008 Can you enable it yourself with the OEM Navi? No. Dealer needs to do it with the Subaru Select Monitor. I installed a shock sensor a while back and haven't gotten around to getting it activated yet.You can enable or disable it using the OEM Navi and you can also adjust its sensitivity (higher value mean less sensitive). Key needs to be in ON position while you do this. Link to comment Share on other sites More sharing options...
Mr. Sinister Posted November 1, 2008 Share Posted November 1, 2008 ;2136905']You can enable or disable it using the OEM Navi and you can also adjust its sensitivity (higher value mean less sensitive). Key needs to be in ON position while you do this. This is only after the dealer has enabled it. Before they did that, neither of those options were there. Link to comment Share on other sites More sharing options...
g2redgsr Posted November 6, 2008 Share Posted November 6, 2008 any way to adjust the sensitivity without the nav? nothing on the box? Link to comment Share on other sites More sharing options...
Mr. Sinister Posted November 6, 2008 Share Posted November 6, 2008 any way to adjust the sensitivity without the nav? nothing on the box? There's an adjustment screw (potentiometer) in the box itself, but that's not really what you should be using. I think of that as more of a coarse adjustment. If you don't have nav, the dealer can adjust the sensitivity using the SSM. Link to comment Share on other sites More sharing options...
g2redgsr Posted November 9, 2008 Share Posted November 9, 2008 There's an adjustment screw (potentiometer) in the box itself, but that's not really what you should be using. I think of that as more of a coarse adjustment. If you don't have nav, the dealer can adjust the sensitivity using the SSM. oh ok, thats how you adjust aftermarket alarms Link to comment Share on other sites More sharing options...
