dmp Posted September 23, 2008 Share Posted September 23, 2008 I was under the assumption Mickeyd's stg 1 tune would 'turn off' CELs - Can anyone help me with how to adjust it to ignore the CEL? CEL due to Catless DP, btw. No other mods. SOLD | '06 spec.B - VF52/AVO/740cc/Up/Down | 238awhp | 50-80mph 3.1 seconds. Link to comment Share on other sites More sharing options...
Dark-V Posted September 23, 2008 Share Posted September 23, 2008 MickeyD's is just a spreadsheet that you add into your current ROM. You need to choose which CEL to disable and manually disable them. Link to comment Share on other sites More sharing options...
dmp Posted September 23, 2008 Author Share Posted September 23, 2008 Thanks - I'll look for that. SOLD | '06 spec.B - VF52/AVO/740cc/Up/Down | 238awhp | 50-80mph 3.1 seconds. Link to comment Share on other sites More sharing options...
dmp Posted September 23, 2008 Author Share Posted September 23, 2008 Found it! Thanks much! SOLD | '06 spec.B - VF52/AVO/740cc/Up/Down | 238awhp | 50-80mph 3.1 seconds. Link to comment Share on other sites More sharing options...
mickeyd2005 Posted September 25, 2008 Share Posted September 25, 2008 You shouldn't run that tune with a catless DP. You'll probably overboost if you have a 5MT. However, it's probably safe because I have the boost limit set fairly low. You'll just get fuel cut right away. Link to comment Share on other sites More sharing options...
dmp Posted September 25, 2008 Author Share Posted September 25, 2008 I'm not over-boosting; I get boost spikes between some shifts at times - but I like it because it's a safe tune until the RomRaider can datalog w/ the 2.0. Really appreciate the tune, Mickey. SOLD | '06 spec.B - VF52/AVO/740cc/Up/Down | 238awhp | 50-80mph 3.1 seconds. Link to comment Share on other sites More sharing options...
