spiderpig Posted September 23, 2008 Share Posted September 23, 2008 I do not want to lower my 08 spec.b however I would like slightly stiffer springs. It seems everyone asks about lowering springs - but are there any good non lowering alternatives? TIA Link to comment Share on other sites More sharing options...
Guest LGT-NY Posted September 23, 2008 Share Posted September 23, 2008 Just get coilover and set them on the highest setting. With stock ride height though, you still won't be able to eliminate body roll, which I assume is why you want to stiffen up the springs. Link to comment Share on other sites More sharing options...
spiderpig Posted September 23, 2008 Author Share Posted September 23, 2008 actually my issue is that with two adults in the rear I can easily hit the bump stops on a moderately bumpy road at speed. I really would like to avoid smacking into the bump stops. Link to comment Share on other sites More sharing options...
Guest LGT-NY Posted September 23, 2008 Share Posted September 23, 2008 Hmmmm.... Not sure if they make any, i'll look around. Link to comment Share on other sites More sharing options...
Long Island Legacy Posted September 23, 2008 Share Posted September 23, 2008 I do not want to lower my 08 spec.b however I would like slightly stiffer springs. It seems everyone asks about lowering springs - but are there any good non lowering alternatives? TIA I think you can possibly source springs from a Rev.C Car i believe the springs on that setup are a tad firmer. Other then that I would say either pinks which drop a tad but nothing major or Rallitek Red springs i think give the car a drop as well but deff have a higher spring rate. Link to comment Share on other sites More sharing options...
fonts Posted September 24, 2008 Share Posted September 24, 2008 I think you can possibly source springs from a Rev.C Car i believe the springs on that setup are a tad firmer. Other then that I would say either pinks which drop a tad but nothing major or Rallitek Red springs i think give the car a drop as well but deff have a higher spring rate. Sounds right. Link to comment Share on other sites More sharing options...
rs6er Posted September 25, 2008 Share Posted September 25, 2008 I have Ion HD springs on my Spec B. They only lower the car a little. (Not like their other lowering springs.) Link to comment Share on other sites More sharing options...
fonts Posted September 25, 2008 Share Posted September 25, 2008 Big drop with Swifts. Link to comment Share on other sites More sharing options...
