djobson Posted September 16, 2008 Share Posted September 16, 2008 I have a 97 Legacy L, for which I want to buy a lightweight crank pulley they have for about $100 or so. I've heard that this might affect the performance of the alternator and possibly air conditioning due to sharing of belts. How accurate is this, and would it be worthy for the slight acceleration improvement? Link to comment Share on other sites More sharing options...
icrackedcorn Posted September 17, 2008 Share Posted September 17, 2008 search an under driven pulley with different belts will change the way your accessories get power there are lightweight non under driven pulleys obedience to church and state is subjugation to the unjust authority of men Link to comment Share on other sites More sharing options...
Elliottlj Posted September 17, 2008 Share Posted September 17, 2008 just get the same size pulley just a lightened one.. thats what i did and it didnt affect shit.. but dont spend 100 on them its not that worth it.. go on ebay and get one for like 80 bucks Link to comment Share on other sites More sharing options...
icrackedcorn Posted September 17, 2008 Share Posted September 17, 2008 mine is form medieval motorsports and cost 70 bucks. stock size, stock belts if i had to do it over, i would have put the money somewhere else first and saved this to be put on after some sways or something more cost effective or more noticeable but id def. get the same pulley for the same price. its good stuff obedience to church and state is subjugation to the unjust authority of men Link to comment Share on other sites More sharing options...
Elliottlj Posted September 17, 2008 Share Posted September 17, 2008 yeah id do the same. but no complaints so far.. mine is an obx lightweight pulley Link to comment Share on other sites More sharing options...
scottmcphee Posted September 18, 2008 Share Posted September 18, 2008 Don't do this. Don't change the harmonic balance of the engine by slapping on a different weighted pulley. The crank is designed as a unit with the weight in mind. You might get new noise vibration and harshness at best, worse, start throwing bearings, seals, or piston parts out. Not cool. Link to comment Share on other sites More sharing options...
Guest Posted September 18, 2008 Share Posted September 18, 2008 Don't do this. Don't change the harmonic balance of the engine by slapping on a different weighted pulley. The crank is designed as a unit with the weight in mind. You might get new noise vibration and harshness at best, worse, start throwing bearings, seals, or piston parts out. Not cool. Well, if true the installation of lightened flywheel should be equally detrimental... I don't think it's quite true. For example certain years of LGT and STI have same short block (exact same part #), yet the flywheels/clutches are totally different. Link to comment Share on other sites More sharing options...
Elliottlj Posted September 18, 2008 Share Posted September 18, 2008 yeah shit happens Link to comment Share on other sites More sharing options...
