RyanE Posted September 14, 2008 Share Posted September 14, 2008 Hi folks, It is clutch replacement time for my '05 Legacy GT, and I'm planning on replacing the flywheel with an '06+ WRX flywheel. Since my car is not modified, I was planning on using an '06+ WRX clutch disk and pressure plate. From what I've read, the LGT clutch disk and the '06+ WRX clutch disk are the same part number, meaning the WRX stock clutch setup should be able to stand up to the extra power from the Legacy. However, I don't have the part numbers, so I can't confirm this for sure. It also seems as if the throw out bearing is the same for the LGT and the '06+ WRX, but again, I don't have part numbers. Searching on the forum hasn't conclusively answered this question for sure, so can someone please check and see if the part numbers are the same? I think the WRX setup would be a nice "mod" for people who have to replace their stock clutch, as it would be less expensive and get rid of the dual mass flywheel. Thanks, Ryan Link to comment Share on other sites More sharing options...
BlackHole Posted September 19, 2008 Share Posted September 19, 2008 Part numbers are not the same. AFAIK the WRX clutch disk is slightly smaller (-4mm? diameter) than the LGT. I may be crazy, but if you are going to spend ~$1000 on a 06 WRX stock clutch, why not spend ~$200 more and go with the ACT street clutch which has a lot more torque capacity? Call it insurance against the power mod bug. Kyle "BlackHole" Link to comment Share on other sites More sharing options...
basky69 Posted September 21, 2008 Share Posted September 21, 2008 Here's the link to 5 Star performance...they are a Subaru dealership in PA. I just purchased the ACT clutch and 06+ WRK flywheel combo myself. http://www.5-starperformance.com/servlet/the-1100/ACT-Legacy-GT-%2806-dsh-07/Detail#itemadded Talk to Jeremy... he'll sell it to you for $799.00 including shipping. Link to comment Share on other sites More sharing options...
RyanE Posted September 21, 2008 Author Share Posted September 21, 2008 Thanks for the info - I talked to my local Subaru parts counter, and they said that the WRX and LGT clutch disks cross over on some, but not all part numbers. Confusing! I would be looking at ~$250 for the throw out bearing, clutch disk, and pressure plate, and ~$220 for the flywheel, so it is the same price as the stock LGT parts, plus I get the "upgrade" of the non-dual mass flywheel. -Ryan Link to comment Share on other sites More sharing options...
BlackHole Posted September 22, 2008 Share Posted September 22, 2008 I would be looking at ~$250 for the throw out bearing, clutch disk, and pressure plate That's cheap - I thought the WRX stock clutch was closer to $400 total. Kyle "BlackHole" Link to comment Share on other sites More sharing options...
RyanE Posted September 24, 2008 Author Share Posted September 24, 2008 I get about a 20% discount, but even without that it's only about $300 for the stock setup. Subarugenuineparts.com has the same parts for about $250, but shipping is a factor. -Ryan Link to comment Share on other sites More sharing options...
