CypherMax Posted August 30, 2008 Share Posted August 30, 2008 I just went stage 2 today man is it great! only one slight problem...when i a shifting at around 2700-3000rpm with slight boost not sure how much but i hear a slight pop from the exhaust. I can only duplicate this noise under those circustances otherwise its perfect. i installed cobb catted dp and grimmspeed up. i have a gfb bov set to 50/50 if that helps any? anyway when i did the install and replaced all gaskets and made sure everything was seated properly and torqued. i the only gasket i reused was the doughnut gasket from dp to mid pipe. i made sure that was properly seated too before tightening. i ran car to operating temp and checked for leaks everywhere and sprayed soapy water to make sure. no leaks so i figured i was good and now i hear this popping noise. with the window open it sounds like its coming from directly under the shifter right were the dp meets the mid pipe. maybe it started leaking after being driven i dont know. then i thought to myself maybe its because im running the 3inch dp into the stock catback and all that air being forced into the stock exhaust is making a backfire. i havnt been able to check it again i will when i get back to work on tuesday. in the meantime has anyone had this problem? maybe its normal idk. thanks! Link to comment Share on other sites More sharing options...
CypherMax Posted August 31, 2008 Author Share Posted August 31, 2008 does anyone have any ideas?? Link to comment Share on other sites More sharing options...
sirsimon Posted August 31, 2008 Share Posted August 31, 2008 Sounds like "afterfire". Such "pop" sounds are quite common on tuned, free-exhaust cars. Link to comment Share on other sites More sharing options...
Zed 2.0 Posted August 31, 2008 Share Posted August 31, 2008 I get the same occasional popping on my protuned cobb / megan racing setup, especially when it's hot out or I'm running the car hard. I don't think it's a sign of any trouble. Link to comment Share on other sites More sharing options...
Darkness of Death Posted August 31, 2008 Share Posted August 31, 2008 i get backfire usually from 1-2 change and sometimes on the 2-3 change as well ~ notice this after changing to the stock sti bpv Link to comment Share on other sites More sharing options...
CypherMax Posted September 1, 2008 Author Share Posted September 1, 2008 I figured it wasn't anything to be too concerned about. Thanks guys! Does anyone know where to get a protune in Monmouth county NJ? Link to comment Share on other sites More sharing options...
unlimited6986 Posted September 1, 2008 Share Posted September 1, 2008 Look around there places in NJ and NY that do great tuning. Link to comment Share on other sites More sharing options...
Darkness of Death Posted September 1, 2008 Share Posted September 1, 2008 there is Innovative Tuning in buffalo, NY Link to comment Share on other sites More sharing options...
Guntrain Posted September 1, 2008 Share Posted September 1, 2008 I figured it wasn't anything to be too concerned about. Thanks guys! Does anyone know where to get a protune in Monmouth county NJ? http://www.precisiontuning.com/06/ Link to comment Share on other sites More sharing options...
CypherMax Posted September 1, 2008 Author Share Posted September 1, 2008 thanx guntrain that's really close to me. So I bring in my so and they can build off the base Cobb maps? Link to comment Share on other sites More sharing options...
fonts Posted September 2, 2008 Share Posted September 2, 2008 No experience with Precision but Mike at Innovative was great. Good luck. Link to comment Share on other sites More sharing options...
