patrack92314 Posted August 26, 2008 Share Posted August 26, 2008 i don't really know where to put this post but i have a question about a turbo kit http://spomotorsports.com/CategorizedTableDisplayTemplateRose.cfm?CategoryID=3&CustomerID=191877 is that a good kit and would it be worth it Link to comment Share on other sites More sharing options...
ehsnils Posted August 26, 2008 Share Posted August 26, 2008 There is always a risk with a turbo kit because you will run the risk of detonation problems because you put a turbo on an engine with high compression ratio and also that the crankshaft/rods can be different. It's probably cheaper to get an used WRX or other engine already with a turbo if you really want to do the job. But I suspect that you will get best bang for the bucks if you buy a turbo car from the beginning and start with that instead. Link to comment Share on other sites More sharing options...
patrack92314 Posted August 26, 2008 Author Share Posted August 26, 2008 thanks man Link to comment Share on other sites More sharing options...
