FASTONE Posted August 25, 2008 Share Posted August 25, 2008 Hello everyone, i have a question, will sti or wrx dp fit on the 05 LGT, i just need one for stage 2, i got uppipe from another member here. And other parts are they interchangeable from 05-07 sti and same years wrx. Link to comment Share on other sites More sharing options...
whitetiger Posted August 25, 2008 Share Posted August 25, 2008 wrx/sti DP is too short to bolt up to the legacy. you will need to have it extended in order to make it fit. Link to comment Share on other sites More sharing options...
FASTONE Posted August 25, 2008 Author Share Posted August 25, 2008 Thanks for the info, how about air intake and stock vf-39 sti turbo. Link to comment Share on other sites More sharing options...
Guest LGT-NY Posted August 25, 2008 Share Posted August 25, 2008 You would need to do an STI swap or go FMIC to fit a Vf39. Link to comment Share on other sites More sharing options...
FASTONE Posted August 25, 2008 Author Share Posted August 25, 2008 so if i swap with sti TMIC, i can use the sti turbo right? Link to comment Share on other sites More sharing options...
Guest LGT-NY Posted August 25, 2008 Share Posted August 25, 2008 TMIC and intake manifold and TGV's. Link to comment Share on other sites More sharing options...
whitetiger Posted August 25, 2008 Share Posted August 25, 2008 you need to swap the tmic, intake manifold and tgv's to make it work. Link to comment Share on other sites More sharing options...
Guest LGT-NY Posted August 25, 2008 Share Posted August 25, 2008 Unless your going for the novelty of the STI swap it makes more sense to go with a FMIC. Link to comment Share on other sites More sharing options...
FASTONE Posted August 25, 2008 Author Share Posted August 25, 2008 but isn't it that FMIC is slower to spool, and what does TGV's stang for? Link to comment Share on other sites More sharing options...
whitetiger Posted August 25, 2008 Share Posted August 25, 2008 tumble generator valve perhaps you ashould do a search on "sti swap" and see what it involves Link to comment Share on other sites More sharing options...
Guest LGT-NY Posted August 25, 2008 Share Posted August 25, 2008 TGV's stand for Tumble Generator Valves, or air tumblers for short. Link to comment Share on other sites More sharing options...
Guest LGT-NY Posted August 25, 2008 Share Posted August 25, 2008 Damn Josh, you keep beating me to it. Link to comment Share on other sites More sharing options...
whitetiger Posted August 25, 2008 Share Posted August 25, 2008 very very sneaky...... Link to comment Share on other sites More sharing options...
Guest LGT-NY Posted August 25, 2008 Share Posted August 25, 2008 Link to comment Share on other sites More sharing options...
FASTONE Posted August 25, 2008 Author Share Posted August 25, 2008 you guys are fast Link to comment Share on other sites More sharing options...
FASTONE Posted August 25, 2008 Author Share Posted August 25, 2008 So it is better and cheaper to do STi swap or just upgrade to bolt on turbo for LGT. Link to comment Share on other sites More sharing options...
Guest LGT-NY Posted August 25, 2008 Share Posted August 25, 2008 It's relative to what turbo and supporting mods you want to go with. Link to comment Share on other sites More sharing options...
whitetiger Posted August 25, 2008 Share Posted August 25, 2008 it also depends on if you are gonna do the install work yourself and if you can find used parts for the sti swap. Link to comment Share on other sites More sharing options...
FASTONE Posted August 25, 2008 Author Share Posted August 25, 2008 This is for future, just want to see whats possible, i was thinking maybe 18g or 20g with FMIC, walboro fuel pump, bigger injectors if i have to, intake, BOV for sound and road tune. Link to comment Share on other sites More sharing options...
Guest LGT-NY Posted August 25, 2008 Share Posted August 25, 2008 BOV for sound This tells the whole story! Link to comment Share on other sites More sharing options...
FASTONE Posted August 25, 2008 Author Share Posted August 25, 2008 No, i know that factory is just fine for performance, but i want keep the LGT happy, i also know that HKS Bov sucks, so i just wanted to know what BOV is sounds good and runs good Link to comment Share on other sites More sharing options...
Guest LGT-NY Posted August 25, 2008 Share Posted August 25, 2008 You want a vent to amtmosphere or a recirc? A VTA BOV will give you the Psshhhtt sounds that you desire. A Recirc BOV will give you the best efficiency and performance but little sound. Link to comment Share on other sites More sharing options...
whitetiger Posted August 25, 2008 Share Posted August 25, 2008 BOV's are not important. spend your money elsewhere. Link to comment Share on other sites More sharing options...
FASTONE Posted August 25, 2008 Author Share Posted August 25, 2008 how about 50/50 best of both, still get the ptshhhh and not loose any performance Link to comment Share on other sites More sharing options...
FASTONE Posted August 25, 2008 Author Share Posted August 25, 2008 Whitetiger, can you recomend sombody in florida for installs. Thanks Link to comment Share on other sites More sharing options...
