dfalk Posted August 23, 2008 Share Posted August 23, 2008 My car just hit 41K miles the other day and its also time for an oil change which im going to do tomorrow. Besides the routine checkup on the air filter, fluids etc. is there anything else i should inspect on the car? What are some known problems on these cars that can be avoided with some preventative maintenance? Also is there anything I should replace after hittin the 40K mark? Link to comment Share on other sites More sharing options...
Bdubs Posted August 23, 2008 Share Posted August 23, 2008 According to the maintenance schedule, you really don't have to start replacing anything other than oil until 60k. It's mainly just a visual inspection of the brakes and suspension, which you could easily do when you rotate your own tires. Link to comment Share on other sites More sharing options...
RustyShackleford Posted August 23, 2008 Share Posted August 23, 2008 According to the maintenance schedule, you really don't have to start replacing anything other than oil until 60k. That's assuming the 30K maintenance was done, which would also include brake fluid flush, air filter, tranny oil, coolant change, maybe plugs. Link to comment Share on other sites More sharing options...
mwiener2 Posted August 23, 2008 Share Posted August 23, 2008 at 42k the wheels fall off My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
iyalla Posted August 26, 2008 Share Posted August 26, 2008 What the heck is "Lubricate Chassis"? Link to comment Share on other sites More sharing options...
mwiener2 Posted August 27, 2008 Share Posted August 27, 2008 the lube all the moving parts on the underside My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
iyalla Posted August 27, 2008 Share Posted August 27, 2008 What do they use to lube? Do they lube the bushings and such or are they lubing things like driveshafts and steering knuckles? Or all the above? Just curious Link to comment Share on other sites More sharing options...
z28dreams Posted August 27, 2008 Share Posted August 27, 2008 Ya I'd make sure the 30k service was done - mostly trans flush / diff flush / coolant flush / brake fluid flush. Link to comment Share on other sites More sharing options...
