jeapskibum Posted August 21, 2008 Share Posted August 21, 2008 I pulled the door open and I heard the sound of metal falling into the bottom of my door. A piece of the door handle mechanism is now rolling around in the bottom of my door. Any tips or DIY on how to take the door apart and attempt to repair the handle? It's a 2005 with 48K so it is out of the bumper to bumper warranty. Link to comment Share on other sites More sharing options...
Bdubs Posted August 21, 2008 Share Posted August 21, 2008 There are steps in this thread to take the panel off: http://legacygt.com/forums/showthread.php?t=20069 Once you get in there, see what exactly has broken. Take a pic of what broke, and many members can get you the part # without having to deal with your local parts dept. Order it online for cost, it's generally close to double at the dealership upfront, fyi. Link to comment Share on other sites More sharing options...
jeapskibum Posted September 18, 2008 Author Share Posted September 18, 2008 So I took the door off easy enough thanks to the link above. It appears that the door handle on the outside is not connecting to the metal bar tham goes down into the open/close mechanism abotu halfway down the door. Can I remove the door handle assembly from the outside or do I have to take the metal part of the interior door off next? Any ideas would be appreciated! Link to comment Share on other sites More sharing options...
Bdubs Posted September 19, 2008 Share Posted September 19, 2008 You are going to have to take the inner panel off and whatever else inside the door to get it out. It doesn't take too much effort. Once you learn how those clips on the metal bars work, it's simple. Just make sure your window is rolled up all the way, or else it is going to get in the way of taking the handle out. Link to comment Share on other sites More sharing options...
xihearthookersx Posted September 19, 2008 Share Posted September 19, 2008 same thing i tell everyone, if it seems like you are pushing/pulling too hard on a panel, you are. just be careful, and you wont have to buy any expensive parts. being patient is the key. Link to comment Share on other sites More sharing options...
