Nickz31se-r Posted August 14, 2008 Share Posted August 14, 2008 Well I purchased farmerjons motegi wheels as he told me that they were checked on brembos and know to fit. So, my problem is that they fit but just barely. The outermost edge of the caliper is roughly 2 to 3mm from the spokes, I am talking a few pieces of loose leaf. Im sure if I was to putz around town everything would be fine. But... I do not do that. It is feasible that the plane of the spokes could change in reference to the caliper under extreme cornering, heating etc. So if the spoke barely clears the caliper I should probably get a few mm spacer or head in another direction. Pics will certainatly follow. What are the smallest size spacers available? Link to comment Share on other sites More sharing options...
chenc544 Posted August 14, 2008 Share Posted August 14, 2008 If you track the car I would be more worry about the caliper expanding under heavy breaking. Repeated heavy breaking would heat up the caliper fast and cause it to expand. I have seen calipers expand enough to rub against the inside of the wheel and made a nice groove at the track. I think you will be OK for the street though. Link to comment Share on other sites More sharing options...
Nickz31se-r Posted August 14, 2008 Author Share Posted August 14, 2008 Funny you say that as I was originally contemplating using the wheels for track or possible autox if and when I got around to it. Chenc...on a side note I still have the L7 badges and may very well have them installed on my new grill over the next few days....I've had them for about 2 years! Link to comment Share on other sites More sharing options...
JonLGT Posted August 15, 2008 Share Posted August 15, 2008 If you are that worried just install a small 2-3mm spacer in the front. Link to comment Share on other sites More sharing options...
Nickz31se-r Posted August 15, 2008 Author Share Posted August 15, 2008 What are the smallest spacers available? I have found the 5mm which would put the 7in wheels new offset at 37 which per xenock would be the lowest possible. Is it necessary to utilize longer wheel studs if the spacer is only 5mm or less? Here are the pics. It is simply to close, I measured using a spark gapping tool the gap is between .6 and .7mm. http://i30.photobucket.com/albums/c311/ZtinkyBritches/DSC001171.jpg http://i30.photobucket.com/albums/c311/ZtinkyBritches/DSC001121.jpg These wheel look sinsiter much more than the current. I am however going to take the gt-v apart and get the dish powdercoated flat black along with the silver center cap, this will result in a gloss black spoke and flat black lip, cap and studs. http://i30.photobucket.com/albums/c311/ZtinkyBritches/DSC001021.jpg http://i30.photobucket.com/albums/c311/ZtinkyBritches/DSC001031.jpg http://i30.photobucket.com/albums/c311/ZtinkyBritches/DSC000901.jpg http://i30.photobucket.com/albums/c311/ZtinkyBritches/DSC001211.jpg http://i30.photobucket.com/albums/c311/ZtinkyBritches/DSC001231.jpg http://i30.photobucket.com/albums/c311/ZtinkyBritches/DSC001261.jpg http://i30.photobucket.com/albums/c311/ZtinkyBritches/DSC001281.jpg Link to comment Share on other sites More sharing options...
nKoan Posted August 15, 2008 Share Posted August 15, 2008 What are the smallest spacers available I've bought 2mm spacers (or 3mm, I can't remember) before. There are definitely smaller ones than 5mm. I'd say 5mm is the max w/o longer studs. Link to comment Share on other sites More sharing options...
Nickz31se-r Posted August 15, 2008 Author Share Posted August 15, 2008 I've bought 2mm spacers (or 3mm, I can't remember) before. There are definitely smaller ones than 5mm. I'd say 5mm is the max w/o longer studs. where? Link to comment Share on other sites More sharing options...
nKoan Posted August 15, 2008 Share Posted August 15, 2008 Sid's Alignment in Downtown Reno. Not online, sorry Link to comment Share on other sites More sharing options...
praedet Posted August 15, 2008 Share Posted August 15, 2008 I have a set of 3mm spacers laying around that I will never use, but they were not cheap to me. They are a very high end set produced in Canada... PM me and I will figure out a price... I have heard 1-2mm for everyday, 5-6mm for track use... Link to comment Share on other sites More sharing options...
