str8dwn Posted August 11, 2008 Share Posted August 11, 2008 I'm not sure what size tire to purchase and would appreciate some help. After comparing my options against the OEM, I'm even more confused. Is nearly 1" larger in diameter and 30 revs per mile too large? Also, because of the profile, I plan to inflate using nitrogen to limit pressure loss and changes in the ambient temp. Stock: 17x7 215/45-17 Revs per mile 846 Diam: 24.6" New: 19x8 Bridgestone RE960AS 235/35-19 Revs per mile: 817 Diam: 25.5" Yokohama S.Drive 225/35-19 Revs per mile: 823 Diam: 25.2" Yokohama S.Drive 235/35-19 Revs per mile: 815 Diam: 25.5" Link to comment Share on other sites More sharing options...
axis008 Posted August 11, 2008 Share Posted August 11, 2008 Subaru guys with 19x8.0" usually go with 215/35/19 or 225/35/19. Personally I would go with 235/35/19, but it has the biggest difference. http://www.1010tires.com/TireSizeCalculator.asp That should help out a little and give some information about speed differences and such. -ben Link to comment Share on other sites More sharing options...
str8dwn Posted August 11, 2008 Author Share Posted August 11, 2008 For the 235, The calculator pops up a message saying to stay within 3% of the original tire size to avoid brake failure! Um...that's not good. Any thoughts on that? My local shop almost balked at the thought of me going 225. Couldn't imagine a 215 stretched on an 8" rim. Link to comment Share on other sites More sharing options...
AJChenMPH Posted August 11, 2008 Share Posted August 11, 2008 I ran 225/45-17 on a 17x8 rim on my old car -- it didn't look stretched at all. My vote: 225/35-19. Andy | My Whips Link to comment Share on other sites More sharing options...
