DarkLegacy Posted August 4, 2008 Share Posted August 4, 2008 I am having some trouble with my turbo timer. When I drop the e-brake the timer just shuts off. I checked the connection to my ebrake and it seems to be grounded properly. Any thoughts or suggestions?? Link to comment Share on other sites More sharing options...
RochNY91TSI Posted August 4, 2008 Share Posted August 4, 2008 Did you install it? I'm pretty sure that what you're describing is normal functionality. The apex-i tt that I had on my talon had a safety mechanism hooked up to the e-brake so that if you disengaged it, the tt would turn off. It's meant so that your car doesn't just take off running (even though the e-brake won't really do anything) Link to comment Share on other sites More sharing options...
JonLGT Posted August 4, 2008 Share Posted August 4, 2008 It is supposed to, its a safety feature. Edit: The car is supposed to shut off if you put the e-brake down. Link to comment Share on other sites More sharing options...
DarkLegacy Posted August 4, 2008 Author Share Posted August 4, 2008 I dont mean that. I'll try and describe it better. I park my car, pull up the e-brake, and then turn the key off and the turbo timer does not count down, it just turns off. Its like I dont have a turbo timer... Link to comment Share on other sites More sharing options...
JonLGT Posted August 4, 2008 Share Posted August 4, 2008 I would say check where the TT is interrupting the ignition. Link to comment Share on other sites More sharing options...
Darkness of Death Posted August 5, 2008 Share Posted August 5, 2008 doesn't seem like it's hook up properly. i personally didn't bother to run the wire to the ground on the parking brake. but i bought the wiring harness. did you buy a harness or had to tap the wires? Link to comment Share on other sites More sharing options...
DarkLegacy Posted August 6, 2008 Author Share Posted August 6, 2008 I have had the timer for about 2 years now.... It has worked fine for a long time and now for some reason it does not work. Its driving me nuts.... I am thinking that something is not right near the e brake Link to comment Share on other sites More sharing options...
ProjectSega Posted August 6, 2008 Share Posted August 6, 2008 This might sound kinda dumb, but have you checked if the TT is just turned off? I had the Apexi one on another car, and the light and everything would still run, but the count down feature was turned off. Link to comment Share on other sites More sharing options...
addison Posted August 6, 2008 Share Posted August 6, 2008 pshh who puts turbo timers on subies Link to comment Share on other sites More sharing options...
Guest LGT-NY Posted August 6, 2008 Share Posted August 6, 2008 Water cooled turbo.... Ahhh, no timer required. Link to comment Share on other sites More sharing options...
addison Posted August 6, 2008 Share Posted August 6, 2008 same reason for an intake in early stages... +1 to the cool factor Link to comment Share on other sites More sharing options...
Guest LGT-NY Posted August 6, 2008 Share Posted August 6, 2008 Riiiiiight..... And stickers add 5whp each right? Link to comment Share on other sites More sharing options...
addison Posted August 6, 2008 Share Posted August 6, 2008 and a wing as big as a 747 and NOS! as we drift off topic.... so yea sounds like a bad install... good luck! :-P Link to comment Share on other sites More sharing options...
Guest LGT-NY Posted August 6, 2008 Share Posted August 6, 2008 Link to comment Share on other sites More sharing options...
JonLGT Posted August 7, 2008 Share Posted August 7, 2008 TTs on our cars are still useful is some cases. Even if it is water cooled it is probably best to let your car cool down after spirited driving. At least it does something. Link to comment Share on other sites More sharing options...
addison Posted August 7, 2008 Share Posted August 7, 2008 TTs on our cars are still useful is some cases. Even if it is water cooled it is probably best to let your car cool down after spirited driving. At least it does something. imo not worth the money for just that Link to comment Share on other sites More sharing options...
Darkness of Death Posted August 7, 2008 Share Posted August 7, 2008 peace of mind for some, i guess ~ Link to comment Share on other sites More sharing options...
Guest LGT-NY Posted August 7, 2008 Share Posted August 7, 2008 If you want peace of mind... Get a mini Zen Garden... :lol: http://i211.photobucket.com/albums/bb93/bpotts1/zen.jpg Link to comment Share on other sites More sharing options...
Darkness of Death Posted August 8, 2008 Share Posted August 8, 2008 that looks like nothing but a litter box with lumps...and one on a stick ~ Link to comment Share on other sites More sharing options...
