Metal2You Posted July 31, 2008 Share Posted July 31, 2008 Just another knew-B question about sizing. I've got my heart set on running Enkei RPF1 17X7.5 with 48mm offset and 6.1" of backspacing wrapped in 235-40-17 Dunlop Direzza Z1 Star Specs. Will my heart be broken if I try to use this setup as my daily driver in the summer and hit a several autocross events and a couple of track days each year? Link to comment Share on other sites More sharing options...
gianspi Posted July 31, 2008 Share Posted July 31, 2008 I'm running 245/40s on 17x8 so these should fit with room to spare. I love my wide tires. enough zip ties and duct tape will fix anything. Link to comment Share on other sites More sharing options...
gianspi Posted July 31, 2008 Share Posted July 31, 2008 Actually I prefer the wider tires for DD because it feels more stable, has a bigger contact patch, and I feel more confident around corners. enough zip ties and duct tape will fix anything. Link to comment Share on other sites More sharing options...
Metal2You Posted July 31, 2008 Author Share Posted July 31, 2008 That sounds like what I want Link to comment Share on other sites More sharing options...
whitetiger Posted July 31, 2008 Share Posted July 31, 2008 I'm running 245/40s on 17x8 so these should fit with room to spare. I love my wide tires. me too. Link to comment Share on other sites More sharing options...
Metal2You Posted August 1, 2008 Author Share Posted August 1, 2008 TireRack didn't have the Direzzas in stock, so I went with Bridgestone Potenza RE01's. The thing is they said the 235 wouldn't fit on the 7.5" wheel . So I went with 225-45-17 instead. [sIGH] Link to comment Share on other sites More sharing options...
EL PAALO Posted August 1, 2008 Share Posted August 1, 2008 235/40 17 is meant for an 8, 8.5, or 9" wheel. The 225 should be more stable and will work very well on a 7.5. Link to comment Share on other sites More sharing options...
whitetiger Posted August 1, 2008 Share Posted August 1, 2008 235/40/17 is actually alittle short for a tire size on our cars. better off with a 235/45 or a 245/40 Link to comment Share on other sites More sharing options...
Metal2You Posted August 1, 2008 Author Share Posted August 1, 2008 I wanted a light weight 17" wheel, so 7.5" was the width I went with. If that means I can't run 235 then so be it. Kinda disappointing to not get as wide a contact patch, but I'll live. 235/40/17 is actually closer in diameter to stock than 225/45/17. Link to comment Share on other sites More sharing options...
whitetiger Posted August 1, 2008 Share Posted August 1, 2008 225/45/17 is a more common size and the tires will be cheaper. also, the extra side wall is good if you are driving on rough roads. Link to comment Share on other sites More sharing options...
Guest Posted August 1, 2008 Share Posted August 1, 2008 I'm running 245/40s on 17x8 so these should fit with room to spare. I love my wide tires. Any rubbing issues? What tires, what wheel offset? Link to comment Share on other sites More sharing options...
whitetiger Posted August 1, 2008 Share Posted August 1, 2008 ^I have those as my daily driver setup on +48mm offset. with proper camber settings and very lowered, i dont rub. Link to comment Share on other sites More sharing options...
Guest Posted August 1, 2008 Share Posted August 1, 2008 What brand/model of tires? (and wheels, btw) Do you have rear camber links? I would guess so. Btw, I hear that sedans have slightly more room in the rear than wagons. Link to comment Share on other sites More sharing options...
